โAug-20-2013 07:24 AM
โAug-22-2013 07:10 AM
โAug-20-2013 07:40 PM
YC 1 wrote:
The refer will not make any noise. It does not use a compressor.
With power off remove the inside shroud from the AC. Turn the fan by hand several turns. Once in awhile they will stick and need a bit of encouragement to take off. After spinning turn it on again and see if it takes off.
Propane refers take 6-8 hours to cool.
โAug-20-2013 01:51 PM
โAug-20-2013 01:30 PM
irishgurl wrote:
The fridge is actually working, just very very quiet. The air conditioner sounds as though the compressor is coming on but no air is blowing out. The fan that I have plugged into an outlet seems to go slower when I put the AC on. Does it take a while? Shouldn't the fan option work?
I have checked all the fuses and all are OK. Even found the two 40 amp ones hidden under the obvious fuse/ circute box.
I really appreciate all of the responses. What a great group!!!
โAug-20-2013 12:11 PM
โAug-20-2013 12:01 PM
โAug-20-2013 11:56 AM
โAug-20-2013 11:21 AM
โAug-20-2013 10:06 AM
โAug-20-2013 10:05 AM
โAug-20-2013 08:56 AM
โAug-20-2013 08:05 AM
โAug-20-2013 08:03 AM
โAug-20-2013 07:44 AM
