Empty Black Tank
Bakers01
Does anyone know a trick to emptying your black tank completely? We also notices an odor when we are unable to hook up to sewer. We use the dropins, but not helping the odor over 3-4 days.
Scott & Steph, Greyson our Cheerleader:B
Molly & Bailey-Our dogs
Jose & Binx-our ferrets
16 REPLIES 16
dadmomh
We installed a Tornado in our ROO HTT and it did a find job. Always, always add about 5 gallons of water and chemicals, if you wish, to the tank after dumping. If you've missed anything, that amount of water will keep it from turning to concrete. Our new TT has a black tank flush hookup and DH has said he likes it a lot - saves crawling around on the ground to hook up the Tornado.
We've been using Odorlos for a few years and have been pleased with it, but have been contemplating the Geo Method. Easy enough and more economical than the Odorlos. We're going to be out of Odorlos before the end of the season, so the test will be coming soon. Sensors are notoriously inaccurate, but those using the Geo say that it helps keep them cleaner and more accurate. That would be a great benefit. Two, maybe 3 trips from now, we'll have an opinion.
Trailerless but still have the spirit
2013 Rockwood Ultra Lite 2604 - new family
2007 Rockwood ROO HTT - new family
2003 Ford F-150
4 doggies - We support Adopt/Rescue.
Sam, you were the best!
Cubbie, Foxy, Biscuit and Lily - all rescues!
Bakers01
I have the Hydoflush and I have the hose attachment that goes down the toilet, but it still seems to get hung up. We mostly stay at State Parks that do not have full hook ups. We spent a while at the dump station when the hydroflush looked clear we used the hose in the toilet (several times) and then headed home. Once we got home I had half of a gal bucket drain out. It was gross!
BarneyS
ToneDog wrote:
Is the quickie flush the same thing as the "black tank flush" that I see offered on some models of new TTs?
Yes, or something very similar.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
wildwest450
I love my hydroflush, it does NOT stick waste to the sides of the tank. I've never had a problem with odors and it takes very little time, not to mention the entertainment value.
MitchF150
First thing to establish, is how do your currently 'flush' your black tank?
Do you let it fill to at least 3/4 full before opening the valve?
After you do this, do you just close the valve and call it good?
I know there are times when you are at the public dump station and all you can do it 'dump and go'... ๐Ÿ˜‰
But, if you are at a full hookup site, with sewer, you have the time to flush your tank.... ๐Ÿ˜‰
What I do when I have sewer at my site is let my tank fill.
Dump when it's full, or before I leave.
Close the valve and run a hose to the toilet and use one of those spary wand things and let it go down the hole of the toilet (if your toilet does not drop straight down to the tank, this is not really an option...)
I twist it around and move it up and down to get the spray around the tank and let it sit and fill up again.
Open the valve and let that drain out. It's amazing how much more stuff comes out... Oh, you should also get the clear adapter thing so you can see how much of this stuff is actually passing thru.. It's gross, but it lets you know you are doing some good! ๐Ÿ™‚
Do this until you see pretty much clear water coming out.
Close the valve and add several gallons of water and add the deoderant of your choice and call it good.
I just wish I could do this with my grey tank, as that smells worse than my black tank.. I've found some tablets you can disolve in your sink that helps, but I wish I could give the grey tank a good flushing too..
Goog luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
ToneDog
2016 Jayco Eagle 338 RETS
2015 Ford F-250 Lariat 4x4 CC Diesel
tkcas01
wmoses wrote:
old guy wrote:
back flushing is for the birds. a quickie flush is 100 times better. uses less water and it does a better job of really cleaning the tank. back flushing will leave stuff hanging to the walls.
While there may be some validity to your point, the fact of the matter is most RVs in ths forum do not have quickie flush attachments, as they are not standard. They have to be retrofitted.
Back flushing is available to everyone without drilling any hole in the black tank and making he upgrade. It is a very convenient way to lean out the tank tat can be done while breaking camp, and can be very effective.
Right. If one was to read the post at the link I provided above, they would learn that I use the grey tank water to backflush using a new accessory I purchased, so uses ZERO extra water. And BTW, my rig does have a built-in flush system, but a couple of years ago something plugged it up - I think something that got past my water strainer.
Roaming Full Timer
IAMICHABOD
JRS & B wrote:
I am a big fan of the "Geo Method" using cheap laundry detergent and a water softener/booster (Borax is the cheapest) along with 4 or 5 gallons of water to create a cleaner and somewhat slippery surface inside of the black water tank. No other drop ins needed.
Other will disagree, and I feel they are probably correct in their beliefs for their particular rig, because every toilet, black water tank design and size, air vent, drain configuration, and combinations thereof are not 100% exactly the same.
But it is cheap alternative, certainly worth a try, and it seems to work great for many of us.
X2 Plus I use my Quickie Flush
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
JRS___B
wmoses
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
BarneyS
Terryallan wrote:
Define "quickie flush"
Quickie-Flush tank spray/rinsing system.
Barney
Not towing now.
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
1492
Moderator
Moderator
Moved from Forum Technical Support
old_guy
