Mar-28-2018 10:25 AM
Mar-31-2018 10:31 PM
wannavolunteerFT wrote:
I had that happen to me back in November in my 2010 F150.. Mine shut off once, restarted and I assumed it might be trash in fuel line (I was stopping and starting and turning around on mountain roads). It stopped again about 5 minutes later so I called for help. I was miles from campground in NGA mountains and several hundred miles from home. I got a tow to local Dealer as I didn't want that happening with TT attached.
Turned out there was a service bulletin for some type wiring short between fuel pump and computer controls. Only took them a couple of hours to diagnose and repair (thank goodness). I was kinda bummed that my local dealer had not mentioned the service bulletin when I had the oil changed/basic service done just a week before.
Mar-30-2018 06:39 AM
Mar-30-2018 05:54 AM
Mar-30-2018 05:53 AM
Mar-30-2018 05:05 AM
Mar-29-2018 11:03 AM
Dozer wrote:
Thanks for all the replies,
It just happened again. To narrow things down I was driving with all the electronics turned off.
I was just coasting up to a red light when it shut off, and it felt like I had downshifted. While it was still rolling I just shifted into neutral turned the key and it took right off.
I'm going to look for something loose under the hood. I'll let you know.
Thanks guys,
Dozer
Mar-29-2018 10:26 AM
Mar-29-2018 08:50 AM
justaboutretired wrote:
Cam shaft position sensor. Had this same issue on my 02 Excursion. There was actually a recall on it. Once it was replaced have had no issues.
Mar-29-2018 08:05 AM
Mar-29-2018 06:01 AM
SweetLou wrote:
Easy check is the obvious. The battery cables
Mar-29-2018 04:59 AM
Mar-28-2018 06:53 PM
Mar-28-2018 12:35 PM
Mar-28-2018 12:21 PM
