May-23-2018 04:20 PM
May-25-2018 07:08 AM
Blanco1 wrote:Grit dog wrote:
Exh brake is bolt on for your truck. Air is handy for air bags and bike tires, etc.
if you're really at 500hp I'm surprised you don't have upgraded valve springs.
It's a great addition.
Who said i didn't?
May-25-2018 06:31 AM
HadEnough wrote:rhagfo wrote:ScottG wrote:HadEnough wrote:
Hmm...not how my exhaust brake works on my 2002 12v Cummins ram that is also a hot rod.
I leave my shift switch on all the time for around town driving and lights too.
The exhaust brake only kicks in when you are off the throttle about 1-2 seconds and in gear. At all other times, it's in standby.
That's how they work.
Yes, that's how it works (with delay) if your able to connect to the trucks ECM.
Some older trucks dont have a ECM connection for the EB so switches have to be installed.
That is really interesting, 2002 should be a 24V with an ECM, and then the EB would have a 2 second delay before applying. If you have a 12V in your 2002 the 12V would be fully mechanical and not have an EMC to control the EB.
I chose to make mine fully manual so I have full control over activation, so as soon as my foot is off the throttle EB is working! Empty it will almost bring the truck to a full stop in 3rd.
That IS really interesting... Since I wrote 12v when I meant to write 24v. Lol. Sorry about that.
That's a cool setup making it fully manual. Have you ever had to replace the switch? I've been cautious of turning mine on and off a lot just so I don't need to replace the switch at the shift.
May-25-2018 06:02 AM
May-25-2018 05:54 AM
May-25-2018 05:33 AM
May-24-2018 03:56 PM
Cummins12V98 wrote:
I always say "Cummings" is a place in GA.
May-24-2018 03:36 PM
rhagfo wrote:Blanco1 wrote:JIMNLIN wrote:
I would contact EB dealers/mfg with those questions. They can give you answers on current their EB for the 5.9 Cummins. Some of the diesel speed shops carries them and can be helpful for tech questions on your modded 5.9 Cummins.
My '03 Dodge Cummins/NV5600 came with the Jacobs through Dodge Businesslink dealers which gave me a Dodge warranty (long gone now). The EB switch is under the shifter knob. It works in all forward gears (even reverse). It stays on with the clutch in or out....has a hi idle/EB on for fast warm ups.
The Jacobs is vacuum operated so it has a vac inline mechanical pump with a long long belt. I've had no problems with mine for over 300k miles.
Vacuum vs air pressure. Most brands are are operated with a remote air pump which are handy for airing up other things.
Airing up other things like what?
It probably would not properly fill up the tire to the proper PSI would it?
That might be a good selling point to me?
That is the PacBrake bonus, on board air. Pacbrake has the option for shiftier mounted rocker switch, simple flick of a finger.
May-24-2018 03:35 PM
May-24-2018 08:18 AM
May-24-2018 07:27 AM
Blanco1 wrote:ScottG wrote:
(BTW, it's a "Cummins")
Darn spell check on my phone!
Of course I know this I've owned this truck about 7 years?
May-24-2018 06:28 AM
May-24-2018 04:35 AM
May-23-2018 11:15 PM
May-23-2018 10:55 PM
