Exhaust Brake - when?
MNRon
I've been pulling the 5er with our D/A that handles it really well. I push the exhaust brake button when going down slopes and it works great. Is this how everyone uses it? Anyone leave it on when not descending?
Thanks.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
8 REPLIES 8
Michelle_S
Yep on all the time. Presently have just over 70K on the OEM Brake Pads and most of that mileage is towing 17K plus.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
joe_b_
I use mine most of the time, when I remember to turn it back on, as mentioned above. Wish the default position of the switch was on, instead of off every time the engine is shut off.
The D/A exhaust brake is real handy to use in conjunction with the cruise control. The cruise will let you get 5 mph over the set speed and then it will activate the exhaust brake and start downshifting the Allison transmission when going down a steep grade. Exhaust brakes need to be exercised regularly to keep carbon build up to a minimum. I try to remember to turn mine on all the time but here in town, I often don't use it, at the slower speeds in town.
joe b.
Stuart Florida
Formerly of Colorado and Alaska
2016 Fleetwood Flair 31 B Class A w/bunks
www.picturetrail.com/jbpacooper
Alaska-Colorado and other Trips posted
"Without challenge, adventure is impossible".
coolbreeze01
The exhaust brake should have been standard from the beginning.
Actually a crime that they weren't.
2014 Sandsport 26FBSL
N-Trouble
Yep, all the time when I tow. Well at least when I can remember to reach down and hit the button (shuts off everytime you cycle ignition).
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
1oldtruck
I use it when towing or hauling anything.
Mandalay_Parr
Mine in on all the time.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
donn0128
Leave it on at all times except on ice or snow covered roads. Reduces wear on your service brakes.
Old-Biscuit
I turn mine own anytime I tow.
I also turn it on sometimes when I'm not towing.
Turn on tow/haul and exhaust brake.....woo hoo!!
