F150 Eco Payload Sticker Question!
jaydub74
I'm looking for some payload sticker information on a few different trucks. I was wondering if the community could tell me what their stickers say. I' specifically looking for the following:
(all Super Crew 4x4 with Eco boost Please)
Lariat with Max Tow
Lariat with Max Tow & Heavy Duty Tow Package
XTR with Max Tow
XTR with Max Tow & Heavy Duty Tow Package
Please state whether your truck has a 5.5 or 6.5 box.
2014 Kodiak 284 BHSL
2010 Ford F350 V10 Crew Cab
Full Timing: 2 Adults, 1 Toddler, 1 Yellow Lab
www.randomgoodness.ca
27 REPLIES 27
bogen2
My cargo limit is 2210 pounds with 3.73 rear end.
2014 Ford F150 SuperCrew - 4WD, MaxTow, HD Payload, Ecoboost
2010 Jayco Jayflight G2 23FB w/ Reese Dual Cam WD hitch
190w solar, 1000w PSW inverter, Prostar PWM controller
womps
2012 Lariat 4x4 Super Crew, 6.5 ft. box, max towing,3.73 rear axle ratio = 1568 lbs. payload.
Tystevens
bid_time wrote:
What is it with you guys? He wants to know what the yellow sticker on some peoples truck says. Simple question - you guys get so far off on tangents that have nothing to do with what the OP asked.
If you don't have a F150 EB you don't even need to post cause you are incapable of answering the question that was asked.
So ... where's your information? :@
I kid, I kid ...
2008 Hornet Hideout 27B
2010 Chevy Suburban 1500 LT, Z71 package, 5.3/6A/3.42
2015 Ford F150 XLT Supercrew, 2.7 Ecoboost/6A/3.55 LS
Prior TVs:
2011 Ford F150 Ecoboost 3.5
2006 Chevy Silverado 2500HD Duramax LBZ
2005 Chevy Suburban 1500 4x4 LT, 5.3/4A/4.10
EcoBullet
Payload on mine is 1794 lbs. Max Tow, not HD Payload, 5.5' bed
Me 1954, Nana 1954, Grandson 2003, Granddaughters 2005 & 2008
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
bid_time
dockmasterdave
I thought it was common knowledge how they BS. Ford tells you they used X amount of weight in cement blocks on a flatbed trailer to get the rating. I think, from experience and what I've read here, factory rating X .75 gets me close and a comfortable pull. I have another thread running on this. Wind drag/weight
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
TomG2
It may not be lying, but haven't you seen the ads that claim huge towing ratings for half ton pickups? The devil is in the details, which they gloss over in the ads. Towing a test weight which has little frontal area is a long way from towing a ten foot tall thirty five foot long travel trailer. You are correct, it is not lying to brag how it can "tow 11,000 pounds".
Tystevens
TomG2 wrote:
It's called gamesmanship (or outright lying, if you prefer). Buy a F-150 off the dealer's lot assuming that it has nearly the same ratings as their few and far between HD models if you want get in trouble.
Why is it lying? There is an easy to read yellow sticker right on the door. If you are truck shopping and care about ratings, it should be the first thing you look at.
No offense to Henry Ford, but I kinda like all of the options. It allowed me to find just what I wanted. For my uses, I feel like the 3.55 gears put me right in the sweet spot of being able to occasionally tow and still get good mileage. If I had a heavier trailer or if I towed more miles a year, I know I could have gone w/ the HD options. Lighter or no towing and I could go 3.31 and get even better freeway mileage. I don't see the issue with having a variety of options. It just means that the consumer has to pay attention a little bit, which I don't think is unreasonable to expect or ask in a $40k transaction.
Oh, and my F150 doesn't have HD tow or payload, but the sticker says just under 1500# (can't remember precisely) for a well equipped XLT screw short bed.
Prior TVs:
TomG2
You may want to look back at a thread showing actual yellow stickers for more information. It is easier for me to say that my truck has 3,000 pounds of payload than it is to Photoshop a fake sticker, although it can be done.
BenK
Read this thread...germain to the OP's question
So confused with tow capacities page 1
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Mvander
14' f150 xlt crew 6.5box 2wd door sticker 2583#.
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
DwnSth
Truck in Sig. Sticker payload 2090 lbs.
2014 Berkshire 360QL
BenK
Lariat with Max Tow
XTR with Max Tow
Your nomenclature is all marketing verbiage which at best is kinda
sorta in a direction of their ratings, but no where near their actual
ratings
What is the GVWR, front GAWR, rear GAWR and the GCWR?
For get about the MTWR, as that is derived from a 'curb' vehicle...which
is the stripper model with no options, other than the tow option and
one 150lb driver. Some full fluids...some half a tank or eve less
Payload/cargo/etc listing on the door labels are also derived from a
'curb' vehicle. This is highly debatable and the only way solve this
is to go out and weigh the vehicle. There has been a few and a couple
have posted to confirm that the label is based on the 'curb' (stripper)
Best to actually weigh it to know what your true payload/cargo/etc is
Saying it is a 'half ton', or whatever is again marketing verbiage
Which half ton? There are three classes within a 'half ton' class A
ditto for 3/4 ton...there are several different GVWR's for that class
and another ditto for 1 ton...there are several GVWR's for that class too
Best to do your research and comparison using all of their 'real' ratings
Here is how the ratings system looks like in graphical form and note
to decide if you believe in the ratings system or not.
If not, then do whatever and know that you have taken them off the
warranty and liability hook.
Also note that advice on these freebie forums is worth the price paid...
plus that they have no skin in the game, nor will they pay for any
outcome from bad advice...
If yes, then learn how the ratings system works
Good luck and ask tons of questions.
howmuchshoulditow howmuchcanitow
