Jun-29-2015 12:52 PM
Jun-29-2015 10:16 PM
eichacsj wrote:
half tons the axles are pressed in, 3/4 tons they are bolted.
Jun-29-2015 10:05 PM
gbopp wrote:
I've never seen anyone on the forum complain because they had too much truck.
Jun-29-2015 09:01 PM
Samsonsworld wrote:
Except in a parking lot. 😉
Jun-29-2015 08:43 PM
ROBERTSUNRUS wrote:BenK wrote:
+4K RGAWR vs +6K RGAWR
Bigger frame
Higher class tires
and a big ETC...unless you are referencing the fake half ton for folks who
insist on only owning a half ton...
🙂 Hi, could you explain what you mean by a "Fake Half Ton"? And what is wrong with owning a half ton? I own a half ton / F-150 is there a problem with that?
Jun-29-2015 08:40 PM
Jun-29-2015 03:46 PM
Bigger frame
Higher class tires
Jun-29-2015 03:27 PM
TyroneandGladys wrote:
What is the advantage/disadvantage of a f250 over a f150 if the drivetrain are the same and the tow capacity on both 15,000lbs? Would be used to pull a 27 foot travel trailer not a 5th wheel.
Thanks
Jun-29-2015 03:00 PM
Jun-29-2015 02:45 PM
Jun-29-2015 02:44 PM
Jun-29-2015 02:30 PM
Jun-29-2015 02:18 PM
BenK wrote:
Higher class tires
Jun-29-2015 02:05 PM
Jun-29-2015 01:48 PM
Jun-29-2015 01:41 PM
