Ford Tow Haul Mode - Do you use it?
mfoster711
I previously had a 2007 F250 Diesel. It had a tow haul mode for the transmission but I only used it once because it did not seem to make much difference and caused my gas mileage to stink. I might be wrong, but I think the tow haul mode would disable overdrive which is probably why my gas mileage stunk.
I now have a 2015 F150 and did some towing today with and without the tow haul mode on. In my F150 it seems to make a bigger difference. When tow haul mode was off I felt like the transmission was shifting way too often. With tow haul mode turned on the transmission shifted less often and seemed to drive better.
I guess I will just drive with the tow haul mode turned on but I was wondering what others do? Do you use it on your F150? Does it make the gas mileage a lot worse?
2015 Ford F150 King Ranch
2014 Outback Terrain 250TRS
Previously:
2007 Ford F250 Diesel
2009 Jayco Eagle 30.5 BHS Super Lite 5th Wheel
30 REPLIES 30
mbopp
Any time I'm towing Tow / Haul is engaged. The grade braking feature is nice but on occasion I'll manually downshift to the next lower gear.
2019 F250 XLT Supercab
Just DW & me......
Mr_Biggles
I always use tow/haul when our TT is hooked up.
2011 F-150 FX4 5.0 3.73 Tow package
2013 Evergreen i-Go G239BH
lawnspecialties
I have a landscaping business. My trailer with mowers is only about 4000-5000 lbs. but I still use tow/haul mode when pulling them.
The only time I might not is with a load under 1000 lbs. or so. Its just so convenient; especially under braking.
Rangerman40
I use tow/haul mode with my camper, but not my boat. It seems to help quite a bit.
deltabravo
Desert Captain wrote:
...Get a Scan Gauge and start monitoring your trans fluid temps.
Scan Gauge is useful, but they are old skool.
Get an Edge Insight CS2 or CTS2. Much more advanced
stickdog
Mountains don't scare me, I have tow/haul!!
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
BenK
Tow/Haul function was invented to protect the automatic tranny when hauling and/or towing
With your old, higher class, TV...it had much more margin (sizing, capacity, etc)
that it did NOT need to try and save the automatic...often
Now with your lower class TV...it is much closer to it's limits/ratings...or even over
So it is trying to protect the automatic more often
Many come here asking your question and highest on their 'have to have' list
is MPG.
A wise choice for MPG, but maybe not in the long run with the cost of having
to rebuild one of the most expensive component/system on most vehicles today
I know that as 'Penny wise...Pound foolish'...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Dave5143
When towing my tow/haul mode is always on. Even when I'm not towing I'll turn it on for those long downhills.
Saves on having to frequently hit the brakes as the downhill speed creeps up.
Dave & Mary
2012 Denali 289RK
Ford F250 Lariat Powerstroke 6.7L Diesel
BB_TX
On my previous truck (2007 F350) and current truck (2012 F350) if the trailer is connected, the truck is in tow/haul. I even use it going down a steep grade when not towing to get the engine/exhaust brake advantage.
It does keep the transmission from shifting so often, just as it is supposed to do and to keep the engine from lugging. But no affect on mileage.
Farmerjon
I agree with all the positive remarks about tow haul mode.
I think it is great for towing and I also use it when I'm not towing. It's great for stop and go traffic and hilly winding back country roads.
On my 2015 F350 6.7 it doesn't activate the exhaust brake unless I have the exhaust brake switch on and if I'm towing the exhaust brake switch is on as it adds a lot to the slowing down of the truck.
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
Desert_Captain
If you are not using your Tow Haul when towing or hauling near or at your GVWR (hence the name), you are cooking your transmission. Get a Scan Gauge and start monitoring your trans fluid temps.
Even on seemingly slight grades the temp will creep up. Engage the TH and it will drop 10 - 15 degrees in just a couple of miles. On long, steep grades (6 - 8%), you can engage TH and cruise for miles to the bottom without touching the brakes all while not burning a drop of fuel. The difference in mileage will be negligible and your brakes will last far longer not to mention avoiding overheating.
I am wrapping up an 18 day trip through the southern Rockies and have used TH about 90% of the time with excellent results. Tow Haul is a wonderful thing but only if actually use it properly.
:C
MitchF150
I can only speak of the 2013 F150 and the T/H mode makes a big difference in towing... I can't say the MPG's change at all, but it drives and handles much better with it engaged..
For one thing, it attempts to keep the trans from unlocking the torque converter, which causes higher trans fluid temps.. It'll hold a lower gear "locked" longer before shifting up if you need the higher rpms to keep the TC locked.
Low rpms does not automatically equal higher mpgs... Trans life has a bit to do with things too and lugging any engine is not getting the best mpg's anyway, so why do it?
Going down hill with T/H engaged will downshift the trans if you hit the brakes too.. Yes, your rpms will rise, but you will get some additional engine braking too.. You might not know to downshift, but the computer does when you are in T/H.
But, at the end of the day, it's up to you when you engage it or not.. I don't just keep it engaged 100% of the time I'm towing.. There are times where it's not necessary, especially going down hill, but I judge that on my own..
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Hannibal
Things have changed a lot since 2007. Tow/haul in my '03 Cummins Ram and '05 Hemi 2500HD Ram left a lot to be desired. Tow/haul in my 2010 F250 is what tow/haul should be. I use it any time we're hitched up.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
ReneeG
Yes on tow haul mode and the braking. Any time you tow, the tow haul mode should be on. As you experienced it allows the truck to work more efficiently, especially up and down grades.
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
3oaks
If my trailer is hitched to the truck, a 2009 F150, the truck is in the Tow-Haul mode all the time. That's what it there for.
