โNov-03-2017 05:52 PM
โNov-04-2017 04:54 PM
Ralph Cramden wrote:
3 degrees side to side of the fridge. On a 30' long rig with the fridge backed up against the sidewall 3 degrees out would mean the rig is 18" higher on one end. Did anyone ever try sleeping, or even walking in a 30' rig that's 18" out of level front to back lol.
โNov-04-2017 03:14 PM
โNov-04-2017 09:48 AM
ScottG wrote:
Can the ARP temp probe be installed through the rear cover or do you need to pull the ridge?
โNov-04-2017 08:16 AM
โNov-04-2017 08:09 AM
โNov-04-2017 07:47 AM
Chris Bryant wrote:
Do yourself a favor and install an ARP Control on your refrigerator, and you won't have to worry about it.
โNov-04-2017 07:42 AM
leatherhead612 wrote:Newer RVs should be fine as long as it's level enough to live in. I make a point of being as level as possible. New fridges are expensive and a hassle.
Seems to be cooling fine, its down to 46 degrees and dropping.
โNov-04-2017 06:10 AM
SoundGuy wrote:Lynnmor wrote:
It is not about operating so much, it is about destroying the cooling system. It must be within 3 degrees side to side and 6 degrees front to back.
That assumes the fridge is mounted along one side of the trailer ... mine isn't, it sits along the rear wall of the trailer.
โNov-04-2017 05:45 AM
โNov-04-2017 05:27 AM
โNov-04-2017 04:34 AM
โNov-04-2017 02:53 AM
โNov-03-2017 09:19 PM
โNov-03-2017 09:17 PM
