โSep-10-2014 04:33 PM
โSep-23-2014 05:44 PM
rhagfo wrote:Taco wrote:
It should be added that the reason to buy a diesel is perceived "seat of the pants" power. Since actual useful pulling power is almost identical. Nearly identical mph up hills nearly identical acceleration with a trailer.
Just feels like it is working less hard to most people and that somehow makes them feel better.Sport45 wrote:
Diesel or gasoline doesn't matter when it comes to the hp/torque curves; it's wide open throttle for both.
This is where I get lost with the "Nearly identical mph up hills nearly identical acceleration with a trailer" thought. I tow mostly from Portland to the Oregon coast two lane twisty roads with some passing lanes. our about 270 hp Cummins can slow to 50 for a 45 mph curve, then in direct drive with 3.55's accelerate to 60 while going up a 5% to 6% grade, without going to WOT!
Keep in mind my torque is developed low, (410# at 1,400 rpm) not HP, I need to get to about 2,700 rpm for max HP.
โSep-23-2014 05:18 PM
โSep-23-2014 05:17 PM
I guess Ford, Ram and GM didn't get the memo when they were setting tow ratings for there HD trucks. Someone should've told them that their gassers could tow just as much. Makes me wonder why they even sell diesels.
โSep-23-2014 04:33 PM
โSep-22-2014 10:28 PM
โSep-22-2014 10:20 PM
rhagfo wrote:rhagfo wrote:Taco wrote:
What assumptions are you using to get a payback at 100k miles.
Cause I sure can't see it with what I believe to be realistic numbers.
Well there is fuel savings even at gas at $3.50 and Diesel at $4.00, but to get the cost of the $8,000 engine back in 100,000 miles you need to save $.08 a mile.
With the assumption of $3.50 gas and $4.00 mileage open road 15 and 19, and 10 and 12 towing the savings is only about $.02 per mile.
The main reason for diesel now is POWER! I tow 11,000# (GCVW 19,000)running between 60 and 65 of the freeway climb grades in OD. On state highways Two lanes) may need to drop to 4th (direct) to run between 55 and 60, this is with 3.55's and about 270 HP.
GoDucks, this was in my post towards the top of the page, I don't expect payback in savings with diesel either. I just have never felt that the cost of operations is that much greater even with the fuel now costing more. It is more about POWER.
I am pretty sure we are both on the same page there.
โSep-22-2014 08:01 PM
โSep-22-2014 07:38 PM
โSep-22-2014 03:37 PM
โSep-22-2014 01:51 PM
โSep-22-2014 12:53 PM
โSep-22-2014 12:08 PM
rhagfo wrote:goducks10 wrote:
So if I buy a diesel XL/ST for $36,000 after rebates and someone else buys a loaded gasser Laramie/Platinum for $46,000 after rebates, I'm expected to recoup cost but the other guy isn't? I don't get it.
Well that is not apples to apples really now is it Go Ducks.
I don't think anyone pays full price for the diesel option, that and the resale on diesel is higher, so the true cost is not $8,000.
I gave a $.50 difference in price and minimized the difference in mileage.
Myself the difference between my old F250 460 ci, and the Ram 5.9 Cummins was double city and almost triple empty highway.
No diesel is not for everyone, and Ford did a great job of using some of the most unreliable diesel engines, with high maintenance cost. This leads to the belief that all diesels are troublesome.
Now they build their own diesels, so you need to pay what they feel repair parts are worth.
With my Cummins, I have three parts choices;
Parts house
Dodge/Ram dealer
Cummins NW
I have found that buying from Cummins is usually the best price.
โSep-21-2014 11:06 PM
โSep-21-2014 09:22 PM
