GM 6.0/4sp vs. 8.1/Allison vs. 6.0/6sp
Brisk
Hi all.
My Towrig in Sig is getting a little long in the tooth. We just bought a New to us Toyhauler which is quite a bit heavier than our old trailer and my truck is hating life lol!! We were planning on upgrading the truck next year anyway but found a trailer we loved so we did that first.
Old 5th wheel was 8k ready to camp. I haven't weighed the new one yet but dry weight is 8200 so an educated guess would be 9500-10500 without "toys" and 12k with.
My plan is to buy a newer used truck in the next year. I have always had GMs and have had great luck with them and I know how to fix them so my plan is to stay with GM. I DO NOT WANT A DIESEL
I am curious if anyone has first hand experience towing with an 8.1/allison truck or a 6.0/6sp truck compared to a 6.0/4sp. Right now I am pulling 6% grades at 35-40mph in 1st gear (my old trailer was 60mph in 2nd)and running in 3rd at 60 on the flats at about 6.5-7mpg (old trailer was 4th at 60-65 and 8-9mpg) I am wondering how much of an improvement I should expect with an 8.1 or a 6.0/6sp.
I know what the tow ratings and hp/torque numbers are but I am looking for some real world experience.
Thanks in Advance!
Brent('85) & Lindsay('86) DDs('08 &'11)
'14 RAM Laramie 3500SRW CCLB Cummins/4x4/68RFE
-B&W Turnover Ball/Anderson Ultimate Aluminum
Toyhauler-'06 Forest River Sierra Sport F32
2001 Malibu Sunsetter VLX Wakeboat
23 REPLIES 23
msmith1_wa
Brisk wrote:
jmp wrote:
I have a 2003 GMC with the 8.1/Allison w 4.10 ratio with 37k miles (extra cab) towing similar weight. It tows 12-13k with ease...you just use more gas on the hills! I could not imagine a 6.0l, regardless of trans, towing this amount of weight. Keep looking for the 8.1. They are out there.
That is good info to have. Thank you. Can you run in OD on the flats pretty easily?
Yes it will run on OD on the flats.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
mbrower
I have the 8.1 towing my signature rig at 15K pounds. I always tow in OD and have no problems. I towed with and without tow haul on. I get a little better mpg out of tow haul mode. I just went on a trip with my brother who has a smaller fifth wheel and powerstroke f250. I paid a little less for gas than he did.
2001 Chevy 3500 Big Dooley 8.1L (496 Cubes)Allison 5sp 4:10
2008 KZ Montego Bay 37RLB-4
jmp
Yes, it will tow in OD on flat ground especially when empty. It will pop out of OD on moderate inclines though. If you can find an 06-07 with the Allison 6-speed, that would be ideal. It is thirsty though even when not towing but I don't care since the motor is bulletproof.
2003 GMC 2500HD 8.1/Allison 4X4
rwess
I had a 2003 1500HD with the 6.0/4speed, 3.73 rear. Great truck, wished that I had kept it. However, it was very thirsty. It would tow very good. I now have a 2010 2500HD 4x4 with the 6.0/6speed, 3.73 rear. It gets a little better gas mileage, around 16 on the interstates, 12-13 around town and 7.5-8 while towing. My current trailer weighs around 9,000lbs and is 36 feet long. I use a 12k Equalizer hitch and it tows great. It was 5 years old on 01 March and has 73,000 miles. Put new Bilstein shocks and Michelin LTX tires on it last year. I just retired and I plan on keeping this one for a long time.
rwess
USN Ret.
2017 Open Range 216RBS
2010 Chevy 2500HD Z71 4x4 LT
Brisk
jmp
msmith1_wa
double post
msmith1_wa
I have an 03 2500HD with the 8.1 and Allison. The Allison is the only auto trans that was installed in trucks with th 8.1. As was previously stated the Sub and Avalanche did not get the Allison because it did not fit. The rear axle in the 8.1 trucks is different than the 6.0 trucks. It has a larger ring and pinion and is the same as is used in the Dmax trucks.
I have mostly towed a 10,000lb gross toyhauler with a quad in the bed also. No trouble maintaining speed when towing even on hills.
mr61impala
I would also take into consideration that the 6L90E transmission has an internal controller (TCM).
Until this application I was not familiar with any component controller that wasn't passively or actively cooled. Your engine ECM likely has cooling fins, your PC has a cooling fan and an OTR tractor has an ECM which is fuel cooled. Processors love a cool environment.
The 6L90E TCM is part of the valve body and lives inside the transmission where it is 160F on a good day.
In 2012 we bought several delivery trucks with the 6.0L engine/6L90E combo, and IMHO the 6L90e does not as age nearly well as the 4L80E.
At about 250K miles the 4L80E will give you a slip code telling you the clutches are getting thin and that it's time for a rebuild.
I have had several 6L90E fail when the TCM engaged an additional solenoid (can you say trans brake?) @ road speed and immediately deposited large pieces of metal into the oil pan.
I believe this controller is compromised in such a hostile environment.
I am not saying that they all fail that soon, only that our 6L90E premature failure rate is much higher than that of the 4L80E and that the damage to the core is much more significant. When it fails it will also require a tow truck, whereas the 4L80e will usually drag it's butt home.
I would go with 4L80E or Allison, both superb choices.
Shopping for Travel Trailer
Kalabin
I had a GM 6.0, 6-Speed, 3.73 in the past and even with the 4.10 gearing I'm not sure I would want to push the 10k mark. Now that heavily depends on where you are towing as well. Brother in law tows a 8000lb trailer up here and complains about the lack of power on almost every trip. Again we don't have much flat roads, always some up down grade and having to regain speed.
I understand that your looking for a newer, gas truck. Have you considered a 2005-2010 F350 with the 6.8 V10 with the 5-Speed transmission? It's numbers are 362HP and 457TQ, pretty comparable to the 8.1. Only reason I bring it up is I think if your looking for "newer" and towing the heavy weights that truck with the 4.30 rear end might be the better of the newer trucks for that type of abuse.
2009 Ford F350 V10 4.10 FX4 Crew Cab SRW, Timbrens, Leer Topper
blt2ski
Moderator
Moderator
IIRC when the 8.1 was in gm twucks, the 6 sp emanual was std, including for the dmax in the early years. It was about 04-05 or there abouts that the auto was the only option in GM rigs.
The 4 sp auto was std behind the 8.1 in burbs.
I would not have any issues with a 4.10 or 4.33 geared 6.0 pulling trailers upwards of 15-20K lbs personally. Assuming I had the correct chassis to go with this drivetrain.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
Brisk
jerem0621 wrote:
I know you said no to diesel and no to anything but GM but the 6.4 gasser in the Ram is the best gasser for towing right now. 400 ish HP and its a beast. There should be some used examples popping up as towers upgrade to diesel.
I'm a Gassers guy like you and would consider any of the big three with the deepest axle ratio possible.
IMHO...an 8.1 would upgrade your motor but the trucks are getting old that surrounds them. If you can swing it I recommend going for the 6 speed. 6.0 or the 6.4 Ram with 4:10 gears
The other option is to upgrade to 4.56 years in your truck now to improve the towing experience.
Good luck...hunting is the fun part.
Thanks!
Jeremiah
I have had several diesels in the past and they cost me a fortune to keep on the road and I was always leery of taking long trips in them. The 6.0 I have now has been the best, most reliable truck I have ever owned. It also has more miles than any other truck I have had.
I would absolutely consider a 6.4 Ram but it is out of the budget. I would consider a V10 Ford but I have a ton of aftermarket stuff (rims, tires, Bilsteins, gooseneck hitch, front hitch, Curt 17k receiver, airbags on order, etc) that I can take off of my truck and put on almost any 01-10 GM 2500HD
4.10 gears are a must have for me. (4.30s if I was looking for a Ford)
I have considered modding my truck with gears, (4x4 means 2x the $$) a cam, headers, custom tune ( I have a Cold air intake and a Superchips programmer now) etc. but I would be spending thousands on a truck with close to 200k on it. I could put that money with whatever my truck will bring and be close to the price of a newer truck that would be better out of the box.
BurbMan
CampingN.C. wrote:
I'm convinced the 8.1 doesn't exist in a CCSB 4x4 that's not a work truck. They are truly a needle in a haystack.
I found a few on Cars.com:
2003 2500LS CCSB 228k miles in TX
2002 Avalanche in Chicago, 96k miles
2006 GMC 2500 CCLB 231k miles in PA
Plus 3 extended cabs, but that's it. Slim pickins indeed. Problem with the 8.1 is that newest truck you will find is 8 years old. If you are interested in going new, I would agree with Jeremy that the Ram 6.4 is the hot ticket. That will be my next truck!
ksss
I can say that the 6 speed 6.0 will pull. I have run as high as 16K with 3.73's at 6-7K feet and I thought it handled the weight well (these were equipment trailers without the wind drag of an RV). My current 6.0 has 4.10's and I have not pulled over 12k with it yet but I like this trucks ability even more than the 2012 3.73's so far. The tranny seems more smooth than the '12. I am a fan of the 6.0 while it is no Duramax, for the money it pulls very well.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
