GM Pump Rub in Transfer Case
Sturgeon-Phish
GM transfer cases 261 and 263 are prone to a condition known as Pump Rub. It is where the pump used to circulate the fluid in the transfer case wiggles back and forth wearing a hole in the transfer case, allowing fluid to leak out and if not caught the loss of fluid will destroy the transfer case.
Know of this condition I installed a modification to prevent the pump rub, but I was too late and had a hole in my transfer case not knowing it. I still had plenty of fluid so the damage was limited to the case housing.
I am currently in the process of replacing the damaged transfer case housing with the pump rub mod to prevent damage in the future.
My point is to frequently check the fluid level in your transfer case, and at the first sign of leakage if you see any, perform the pump bub fix.
Jim
2003 GMC 3500 crew dually. Transfer Flow 50g aux tank; ISSPRO gauges, PPE boost valve, air box mods, stock exhaust w/o muffler, Line-X, Pace Edwards bed locker power tonneau. B&W Companion. Pulls a '05 Wildcat 31QBH 5th wheel
23 REPLIES 23
All_I_could_aff
Maybe I've just been away from four-wheel-drive trucks for a while but since when have they used an actual pump in the transfer case? Any transfer case I ever opened many years ago was just splash lubrication... My how the years have passed! This here used to be all farmland as far as the eye could see!
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
Mote
1oldtruck wrote:
Where did you find a new housing? My brother has the same problem and all he has been able to locate are entire transfer cases.
http://www.merchant-automotive.com
They have complete cases, kits to fix the problem on your case or just the tail housing.
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
Dadoffourgirls
I had pump rub on my Yukon XL. Had less than 70k miles. I knew something was happening because I had a oily substance on the back of the vehicle after driving.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
mtofell1
My 2006 developed a leak from the xfer case and it wasn't the famous pump rub. Be carful assuming just because you get a leak. With all the people having the problem I realize I'm probably in the minority but be sure to diagnose the problem correctly and don't assume.
RADROG
My 2002 2500HD/8.1/Alison had pump rub...rubbed a hole right through the magnesium case. The hole was there for 2-3 years and I finally checked the fluid. It was bone dry of course. Put a little JB weld on the hole and refilled. It works fine to this day. 240,000 mile still going strong. Is it really that big of an issue?
2005 American Tradition 370 Cummins ISL
45Ricochet
Yes they are as rare as Black Rhinos and they fetch top dollar at the scrap yards.
Just changed my fluid the past week, should have saved my money till next time. The band adjustment on the tranny sure made a big difference though.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Bull_Rider
We took our 2006 Duramax in and had to condition fixed before it became a problem. We plan on keeping the truck so it needed to remedied.
If you receive help from other members, don't forget to update your topic with the results.
1oldtruck
Thunderbolt
I have heard many stories about pump rub, but have had no issues yet.
I have one truck with 360,000 miles and one with 145,000. I thought about doing the upgrade, but I just keep an eye on it.
Bryan
2003 2500HD Ext. cab short box
6.0 liter 4.10 gears, Nelson performance PCM 293,000 miles
98 K1500 4x4 heavy duty 1/2 ton (Sold)
6,600lb GVWR 5,280lbs on the scale empty
14 bolt rear diff. 3:73 , Tranny and oil coolers
380,000 miles.
