Good Customer Service from Arctic Fox
CAJW
Just wanted to relate an act of good customer service from the Arctic Fox (Northwood) folks. Recently I power drained (used the pump) to drain the water tank faster of our 2013 AF 996. Next time we loaded up, the water pump would not pick up or hold a prime. Pulled the strainer and found it full of plastic shavings left over from the assembly process (probably drilled for fittings about 5 minutes before quitting time on Friday ;). I contacted Northwood about the issue and was directed to my nearest dealer. I noted that we were loaded, ready to go on a trip, but that dealer would be a few hours out of our way. Dave Mann of Northwood said that we bought the camper to use and they wanted to get us back on the road as soon as possible so he directed me to choose any RV repair place I wanted and have them call for payment arrangements. We found a dealer along our route, got the pump replaced in about an hour, had the service manager chat with Northwood and with not a penny out of pocket, we were back on the road. Good follow up on the part of Northwood to correct a problem, which is the true test of customer service.:)
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
10 REPLIES 10
Mogy
Dave Mann at Northwoods is awesome. He recently helped me address a failed slide bearing when the local dealer wouldn't.
'08 Ford F-450 Diesel, Quad-cab, DRW, Torklift & Happi-Jack
Arctic Fox 1150. And one camp dog.
n7bsn
trail-explorer wrote:
Even using the low point drain to "drain the tank" requires use of the water pump.
The do have low point drains as well as a tank drain, but I can see the purpose of using the tank to pump the water out - it's much faster. Using the drain takes FOREVER (at least on the rigs I've had it did)
On our current Northwoods the fresh-tank dump valve is huge (now this may not be true of all current Northwoods product. Dumping the fresh is fast
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
abslayer
To often all we hear is bad things about manufactures and are dump on in web sites.
It is nice to see this thread and is something we should all do , not only report bad service but also good services needs to be pointed out as well. :C
Scott16
Great news to here about customer service from Arctic Fox, Northwood Industries.
Fixing your your water pump in time to continue on your trip. A class act for sure.
Scott
US Navy Retired IC1(SW)USS Fletcher DD-992
trail-explorer
jimh425 wrote:
One other note, do you have a low point drain?
Bob
kerry4951
I always had great customer service from Arctic Fox. Glad to hear they came thru for you.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
n7bsn
jimh425 wrote:
I suppose that's good, but I'm surprised that it didn't start working after you removed the shavings. One other note, do you have a low point drain?
I am not aware of any Northwood product that does not have a low-point drain
BradW
Good to hear the Arctic Fox folks solved the problem quickly on short notice.
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
jimh406
Natt85
Great to hear!
Natacha "Frenchie"
2013 Arctic Fox 811
2001 F350 PSD DRW 4X4, air bags, 9000xl rancho shocks, Roadmaster sway bar
"ex-fulltimer" in a 2001 Arctic Fox 5th wheel 29-5T
