Good Grief a tire question
tomman58
Howdy,
Boy I hate to ask this......................
I had a blow out on a 225.75R. 15 tire. The tire was but a year old, oh well. I was only able to get a load E tire. my regular tires inflate to 65 lbs the E can be at 80. I had Campers world put the (already mounted) E on the trailer and I think they adjusted it to 65 lbs..
Is this OK or should I ramp it back to 80. I may get 3 more E's when I get home in a few months but for now with about 7000 miles to go what is the best for the TT tires now.
TIA
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
29 REPLIES 29
enblethen
I still say it is not enough and to read and use sidewall until you get it weighed.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
temccarthy1
THANKS for all your input! Sounds like "50 lb rating" should be filled to 50 lbs all the time... not 45! 50 lbs it is! Thanks as always for sharing your experience!
Tim, Ramona and dog Scruffy
1982 Coleman Sun Valley PUP (retired)
2014 Keystone Bullet 285RLS Ultralite TT
2013 Ford Expedition XLT 5.4L Triton V8
Equalizer E2 hitch
gmw_photos
bhall wrote:
nobody asked what is the max pressure rated for the WHEELS themselves?
there is a good chance the wheels do not have a air psi rating, only a load in pounds ( weight ) rating.
bhall
rbpru
My TT manual says 50 psi and they are quite repetative on that point.
So I run 50 psi. cold pressure.
I purchased a three year old used TT and have towed over 14,000 miles in the last two and a half years. I will replace them next spring since, the tires are dated 2009 and I am planning another Western trip.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
BarneyS
I would run all your tires at the max pressure as stated on the sidewall. Sounds to me like you have C rated tires and not D.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
hohenwald48
This web site has all the tire info you could ever want. The pressure vs load capacity chart is on page 7. Not 100% sure but I think load capacity for a given tire size is the same regardless of tire brand.
http://www.trailmastertrailers.com/pdf/proper_tire_care_safety.pdf
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
gmw_photos
temccarthy1 wrote:
I have a question and need advice.. I have a new 2014 Keystone Bullet 285RLS TT with the standard load range D tires with 14 " wheels.. It says max pressure 50 lbs on the sidewalls. When I bought the TT , I had the dealer check air pressure in front of me and they were at only 40. Tech said that is fine. I insisted he fill them to 45 and he did. I used the TT only twice this year an tested them at 45. Tires and hubs remained cool to touch when I checked at rest stops. Should I be running these exactly at 50 at all times in hot weather and cool, or do you think 45 is the sweet spot. Would like to hear from Rv'ers with a lot of experience on this subject. Thanks!
Are you sure those are load range D ? Typically, LR D would have a max pressure of 65psi. Load range C is typically 50 psi.
Whichever is on there, if it were mine I would run the max psi that is stated on the sidewall of the tire.
Chuck_thehammer
Max air pressure is posted and used so tire can carry the Max weight it is designed for....
if stated 50... run 50... my opinion. max life, max load.
B-n-B
tomman58 wrote:
Howdy,
TIA
What brand "E" rated tire did you use?
2019 Chevy 3500HD LTZ DRW
2025 Bigfoot 10.4
temccarthy1
BTW.. My TT weighs 5500 lbs and is 30 ft long
Equalizer E2 hitch
temccarthy1
Equalizer E2 hitch
enblethen
What does the rig weigh?
What does the sidewall say for max air pressure?
Until you get the rig weighed, put max air in all the tires(if they are rated all the same)
Bud
USAF Retired
Pace Arrow
Chuck_thehammer
I would use 65# as well.
but remember to check TIRE HEAT .. new one to the others... should be almost the same...
coolbreeze01
65# in the new E tire will be fine. At only a year old, if defective, you should get an adjustment on the ruined tire.
When you have 4 E rated tires on your trailer, then 80# is what I would run.
2014 Sandsport 26FBSL
