GVWR Question
knesdad
The truck in my signature has a GVWR rating of 7,700 pounds. The combined axle weight at my last weigh in was 8,100 pounds. Problem? (Trailer weight was 6,340. Combined was 14,440.)
Thanks.
Dave.
Dave & Sue
Kiley & Emily
Izzie (Beagle/Bichon/Mini Poodle)
2012 Ford F150 XLT EB SS CRW 6.5 Max Tow
2012 Dutchmen Kodiak 284BHSL -- Dutchmen Owners
22 REPLIES 22
rhagfo
wilber1 wrote:
Probably not a problem as long as you are within your axle and tire ratings. Legality might be an issue. Some places, GVWR is a legal limit and others it is not. Depends on what you are comfortable with.
Yep you might check the axle ratings, you are likely exceeding one or both ratings. Newer F150 run a GVWR that is 95% or better of the total GAWR.
I run over my GVWR, but still well within GAWR and tire weight ratings. In addition I do it on full floating axles, much stronger design than the semi floating axle in your F150.
TomG2
Engineers don't have a clue what your vehicle is capable of when they assign those Gross Vehicle Weight Ratings. They should change them to Gross Vehicle Weight Guesses. Most owners and lots of contributors on here know more than they ever will. The ecoboost will pull even more.
In case anyone doesn't get it, I am being sarcastic. I have never had a tow vehicle that was comfortable when exceeding its manufacturer's ratings. Yes, I have done it and got by with it, just as others might.
fla-gypsy
It would be a problem if it were me, only you can decide what you will believe. Either you believe the truck maker or all of the folks that will say "no problem".
wilber1
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
45Ricochet
Ah WTH is 400 lbs between friends. It happens all the time. Some push it to 800 lbs, others 1200 lbs. Ratings is just a word, nothing more apparently. Kind of like your virus protection on the puter which says not to open a internet site. People do it all the time for some reason. We humans can't help ourselves in going over the line :B
Having said that, your tire ratings should never be exceeded ever. You might very well have "P" rated tires which will have lower sidewall ratings.
I'm out
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
mdamerell
PDF file of Ford 2012 spec's
This should give you all the numbers you need to figure out how far you feel comfortable.
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
knesdad
I did have extra stuff in the bed that more than likely brought the weight up. Just wanted to make sure I was reading the numbers right...
Dave & Sue
Kiley & Emily
BurbMan
You're 400 lbs overweight, you tell me if that's a problem....if it was me I wouldn't worry about it just keep the trailer brakes turned up and drive accordingly.
