Help...6.7 CTD smoking (update: Cracked injector)
RamGuy2500
Took the truck out for the 4th of July on a long haul and now my truck is blowing white smoke during acceleration. I'm completely stock and don't abuse my truck. All fluids and gauges look good. What could cause this?
2018 Ford F-350 XLT, 6.7 Powerstroke ๐Ÿ˜„
46 REPLIES 46
Bigfoot_affair
Nomad II
Nomad II
SoCalDesertRider wrote:
I would not drive it. A tow to the dealer is much cheaper than a blown engine.
X2, if the injector is stuck open it could torch the piston.
FWIW I have never seen my truck smoke during a regen..
SoCalDesertRid1
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
carringb
X2 on not driving. If it's the EGR cooler, it can cause more damage. If its the DPF if means its trying to burn off excess fuel, which could end up fouling it or plugging it with ash. A 2014 won't ever smoke during regen. Actually none of the 6.7's do, unlike the Ford 6.4L.
2014 ORV really big trailer
2015 Ford Focus ST
kc8yhk
RamGuy2500 wrote:
#40Fan wrote:
I wouldn't worry too much. Get it to the dealer and let them handle it. I am sure it isn't anything you could have done, even if you pegged it on the redline.
I think you're right. I'll try to get it there soon. Will I damage it if I keep driving it until then?
I wouldn't advise it, get it looked at asap.
krsmitty
kc8yhk wrote:
Injectors.
X2. Have any issues with getting water in your fuel?
Ken Smith
2017 Dodge Ram 2500 Big horn 4x4 6.7 CTD
2020 Grand Design Reflection 287RLTS
transamz9
I'm going to say you are just going through a heavy regen. My 13 did it too. If you drive around like you have an egg under the pedal the exhaust builds up.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
mrkoje
Get it there before your 3/36 warranty is up just to be safe
RAPTOR 300MP
RAM 3500 MEGA CTD 4X4
Me_Again
https://www.injectorsdirect.com/does-white-smoke-mean-injector-problems/. Chris
RamGuy2500
_40Fan
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
kc8yhk
The more I load down my truck the better it runs. The most common turbo failures that I've seen is the variable veins start sticking, but you'd notice that with a loss of power, and that "usually" starts acting up around 70k miles. My first thought was maybe a blown head gasket but you said all the fluid levels are normal. Have you pulled the dip stick as well? Oil color and smell normal? Is it making oil?
RamGuy2500
kc8yhk wrote:
How many miles are on your truck?
31K, mostly highway. Do you think I damaged it pulling the fifth wheel? I traveled 400 miles round trip at 60-65 mph. Everything seemed fine and I don't remember any issues. I've never redlined it or had any issues until now.
kc8yhk
RamGuy2500
Turtle n Peeps wrote:
What does the smoke smell like?
I'll have to check in the morning. I've just noticed it while driving around recently.
RamGuy2500
kc8yhk wrote:
Injectors.
On other forums I'm also reading that it could be the turbo or seal around it.
