Feb-19-2014 06:44 AM
Feb-20-2014 06:58 PM
Feb-20-2014 02:37 PM
Feb-19-2014 06:24 PM
Feb-19-2014 05:47 PM
Feb-19-2014 01:50 PM
carringb wrote:rhagfo wrote:The Ram is only only comparable to the current F450. The new F450 will become a big-boy truck again. I believe Ford will re-introduce the "Wide-Track" option into the F350 again, which effectively makes it the same as the current F450.Perrysburg Dodgeboy wrote:
Yep if you can afford the upgrade do it. You should call your insurance company and the State you live in. You should check with your insurance to see what jumping in to a 450 will do to your cost.
Don
The RAM 3500 has as much capacity as a F450, if insurance or licensing are issues with the F450.
Feb-19-2014 01:27 PM
vr200275 wrote:
I believe the 2015 F-450 will have the 19.5" wheels and tires, ten lugs and bigger brakes like the 2008 - 2010 F-450's had.
This should make quite a difference in towing and payload ratings.
The current F-350 and F-450 seem to be very similar.
Feb-19-2014 01:12 PM
Feb-19-2014 09:30 AM
Feb-19-2014 08:40 AM
Feb-19-2014 08:38 AM
Don
Feb-19-2014 08:35 AM
Don
Feb-19-2014 08:02 AM
Don
Feb-19-2014 07:52 AM
Feb-19-2014 07:39 AM
carringb wrote:
I would go F450 for sure now that it has 19.5" wheels (again).
