โJul-11-2014 08:30 AM
โJul-12-2014 01:12 PM
dave17352 wrote:
Really, is that all it is a sticker? Interesting I thought maybe different tires and rims.
โJul-12-2014 08:40 AM
โJul-12-2014 05:06 AM
Here's an interesting question on that. Does anyone know the difference between a SRW 350 with the 10k GVWR package vs. a SRW 350 with the 11400 GVWR package? Is it just a sticker to get past the CA regs or is there a physical difference?
โJul-11-2014 11:04 PM
โJul-11-2014 10:43 PM
JIMNLIN wrote:
F350 SRW trucks come with a 10000 lb GVWR up to a 11500 lb GVWR.
One new poster had a question about his F350 SRW having a very low payload number. The reason was he had a F350 SRW with a 10k GVWR instead of the higher 11xxx GVWR.
Now my point here is pay close attention to the trucks numbers your buying.
Example from Fleet Ford specs:
'14 F350 SRW 4x4 CC 172.4" 6.7 diesel with a 11200 GVWR has a 3560 lb payload.
'14 F350 SRW 4x4 CC 172.4" 6.7 diesel with a 10000 GVWR has a 2360 lb payload.
The same configured truck in a 10000 GVWR F250 has a 2410 lb payload.
So saying a F350 SRW has more payload potential isn't always true as the poor poster I mentioned above found out. 'Course he was educated about GVWR not determining how much a load a truck can carry.
I've always bought the size truck I wanted and simply matched the weight of the trailer to the truck axle/tire load ratings...... using it as a max load if needed.
โJul-11-2014 08:43 PM
โJul-11-2014 08:19 PM
โJul-11-2014 08:00 PM
โJul-11-2014 07:07 PM
โJul-11-2014 05:36 PM
โJul-11-2014 02:45 PM
โJul-11-2014 01:40 PM
โJul-11-2014 10:58 AM
โJul-11-2014 10:40 AM
โJul-11-2014 10:21 AM
