Mar-17-2015 08:23 AM
Mar-17-2015 12:59 PM
marquette wrote:
Here is a example of one of the trailers we looked at and the others are similar.
1995 Komfort Lite 22LF Listed at 3442 lbs. So I figure 5000 lbs loaded. Some of the others were in the 3800 lb do 5500 lb loaded. Imperial camper in Newport, Mn has it if you want to google the listing.
Mar-17-2015 12:28 PM
Mar-17-2015 12:21 PM
Mar-17-2015 11:29 AM
Mar-17-2015 11:18 AM
APT wrote:
GM replaced the 454ci (7.4L) from the 90's with the 496ci (8.1L) for 2001-2007. It was dropped due to emissions and demand. 😞 It was a beast.
Consider the fuel tank size too. My prior TV had practical RV towing tank range of 160-200 miles. It was a nuisance at best for short in-state trips. My new TV tank range is 250-325 miles much better.
Mar-17-2015 11:17 AM
Mar-17-2015 11:16 AM
Mar-17-2015 11:07 AM
marquette wrote:
Is the 8.1 the same as the 454?
Mar-17-2015 11:05 AM
Mar-17-2015 10:51 AM
Mar-17-2015 10:46 AM
Mar-17-2015 10:41 AM
APT wrote:This is what I would go with as well. If you wanted to go to a larger trailer you would not be limited by the truck. The trade off is unloaded fuel economy. Pulling the camper the mileage would be similar.
From that era, I recommend GM 8.1L and Ford V10. The small blocks didn't have the power of today's full sized pickups and were mated to 4-spd transmissions. The only penalty of the bigger engines from that era is unloaded fuel economy compared to say GM 6.0L or Ford 5.4L.
Mar-17-2015 10:28 AM
Mar-17-2015 10:01 AM
Mar-17-2015 09:44 AM
