โFeb-15-2015 03:10 PM
โFeb-16-2015 10:31 PM
Ron Gratz wrote:
IMO, anyone who questions the importance of GVWR (or any other rating) should read Trailer Towing Illegally.
Ron
โFeb-16-2015 07:33 PM
spoon wrote:
Larry, I think you are right and I misspoke. FMVSS standards (I googled them) are for crash safety and crash avoidance. It has NOTHING to do with GVWR or axle ratings.
I forget what standard applies to vehicles to determine ratings. For some reason I thought FMVSS determined that.
โFeb-16-2015 07:29 PM
โFeb-16-2015 04:38 PM
blt2ski wrote:Marty, just because you drive over the gvwr without issues, doesn't mean that everyone can do the same.
I drive over the gvwr without issues, ---
โFeb-16-2015 04:32 PM
spoon059 wrote:There are over 200 FMVSS regulations. They cover everything from lighting, to crashworthiness, to braking.
โFeb-16-2015 11:45 AM
โFeb-16-2015 10:03 AM
โFeb-16-2015 09:20 AM
โFeb-16-2015 09:14 AM
โFeb-16-2015 08:45 AM
APT wrote:
Payload per the tire and loading sticker includes all fluids such as a full tank of fuel. No driver or other passengers, though.
โFeb-16-2015 08:43 AM
โFeb-16-2015 08:31 AM
โFeb-16-2015 08:27 AM
TomG2 wrote:
The manufacturer says that I can haul 4 passengers in my vehicle, but I could probably cram in 8 if I really tried. Don't you think they know something about a vehicle's capacity, including its gvwr?
โFeb-16-2015 08:07 AM
spoon059 wrote:LarryJM wrote:
For me I'll treat the FMVSS certified safety limit as a hard one since insuring one is under it is not that hard.
Larry
FYI, the FMVSS rating for my axles in the Tundra is over 8300 lbs with stock P rated tires. I'm not sure what the rating is with my OEM E rated tires, but its likely even higher than 8300 lbs. That being said, Toyota REQUESTS that I keep my GVWR to under 7200 lbs. According to YOUR logic (FMVSS safety limits are the hard and fast rule), then I have an additional 1100 lbs of payload.
Payload ratings from manufacturers are required to be at or under FMVSS ratings, but they are numbers assigned by individual manufacturers with little to no oversight... so long as they are at or under FMVSS ratings. Toyota chose to be conservative and de-rate the Tundra by 1150 lbs or so. They did that to reduce wear and tear, reduce warranty issues and increase the duty cycle of the truck.
I understand the point of your argument, but your supporting documents don't correspond with your argument.
โFeb-16-2015 07:49 AM
