How tight?
Dtaylor
Having OCD, there are little stupid things that absolutely bug the snot out of me. One of those is how tight to you tighten down your stabilizer jacks after they make contact with the ground (or blocks). Do you go one turn past when it makes contact, do you go two turns?? What do you do?
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
29 REPLIES 29
DE88ROX
I run mine down with the drill. I stop when the trailer frame starts to rise.
But you will always get some movement as long as the tires are sitting on the ground.
Some type of X-chock, either store bought or home made helps take a lot of movement out of the trailer.
[COLOR=]TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
atreis
downtheroad wrote:
I tighten them down until it, "feels right."
X5 (or something like that).
It depends on the nature of the soil... More for sand, less for stone.
2021 Four Winds 26B on Chevy 4500
johnnstace
Jayco254 wrote:
Once they hit the ground I give them one more good crank on a paved pad on a rock pad if it's kind of soft I go more by feel.
same here. I also find that if on softer ground I need to give a little more after a day or so to re-stabilize. This is determined by the amount of trailer wiggle while walking about inside.
johnnstace
X2
robsouth
Howie3 wrote:
robsouth wrote:
I run mine down to the ground and then turn 1 13/16" more. :B
Really? I find that 1 25/32" is much preferable.:W
Howie
I'll give 1 25/32" a try, but loosing that 1/16 may not work for me. What do you think about splitting the difference at 1 51/64"?
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Jayco254
Tom, Kathy, Nikki, & Kelly
Pets: Lady - Texas Heeler, Dinger - Rhodesian Riidgeback Mix
2008 Ford Expedition Eddie Bauer 4x4 5.4 ci 3.73 gears
2008 Dodge Ram SLT Big Horn 4x4 5.7L Hemi 3.92 gears
2007 Jayco Jayfeather EXP 254
Husky W/D, P-3
BarneyS
Same here. ๐Ÿ™‚
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
fallsrider
I'm experimenting with "3" on my Dewalt 18v clutch. Will see if that works under varying conditions.
opnspaces
Navigator II
Navigator II
I lower them until they touch and then give ~120ยฐ more.
ROBERTSUNRUS
๐Ÿ™‚ Hi, if parked on Concrete, I only go 1/2 turn after they hit the ground. If on something soft, like dirt, I go one full turn.
๐Ÿ™‚ Bob ๐Ÿ™‚
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
Howie3
Actually it depends on how firm the ground is. I turn it til it feels tight without starting to lift the trailer frame. Might be 1/2 turn or 2 turns after it touches the ground.
Howie
PZebich
I level trailer side to side with boards under low side wheels.
Then I put down pads under each jack then take them down till tight and then go one more turn. Old aircraft mechanic method.
DarthMuffin
Robby9 wrote:
Set drill chuck to 8, spin till the clutch pops.
Same here, but on my drill it's "20" (which is of course a totally made up number and will vary drill-to-drill). A wonderful way to get each stabilizer consistent every time without trying.
Robby9
