โJan-06-2016 05:46 PM
โFeb-11-2016 12:30 PM
sabinazeeb wrote:
Hi,
I own a 2007 Chevy Classic, 2500 HD ...I was still wondering if I can improve safety....
โFeb-08-2016 08:50 PM
edatlanta wrote:SDcampowneroperator wrote:
You have an '07 LBZ 6.6 with Allison 6 speed. The dream combo. Don't mess with it. Fuss with your suspension,tires or such, just not the driveline.
Mine is an 2006 LBZ and I'm not touching it EVER! I get 12.0-12.3 mpg towing my 5'er. ENUF said!
โJan-11-2016 12:39 PM
N-Trouble wrote:I have 160k miles on my truck and it's had a heavy tow tune for the past 4 years. The best thing I ever done and would do it again in a heartbeat. No issues and it actually dropped my engine temps. My 5ver is over 12k lbs. and I've never seen EGT's close to 1300 degrees. I went with a reliable EFI live programmer in Idaho Rob.RCMAN46 wrote:Grit dog wrote:N-Trouble wrote:
A mild "heavy tow" tune from one of the reputable Duramax EFI live tuners will do wonders. Don't believe all the naysayers who say it will just ruin your truck. Simply not true... If you want to inquire more head over to the Duramax forum.
This^
Never even heard of a black bear tune?? But EFI or other reputable tuners can get u the power of the new trucks for pretty cheap.
Just know how to use it.
Go over to the Diesel forums and you will find that about 90% of the engine and transmission problems are on trucks with tunes.
I have a 2005 Dmax and have never been short of power for normal towing at posted speed limits.
The 2007 has more power than the 2005 and also the 6 speed.
I would trade for a classic 2007 at the drop of a hat and be happy with the stock configuration.
So NOT true... Majority of issues on current diesels are emissions related on bone STOCK trucks and why so many these days are tuning. Simply to get rid of the troublesome ****.
Tuned guys that are dropping transmissions are typically running "hot" tunes that run their trans at the very edge. If you would have read my post you would have seen I specifically said a mild "tow" tune. There are lots of high mileage tuned trucks running reliably on the road.
โJan-11-2016 06:29 AM
โJan-11-2016 06:20 AM
Turtle n Peeps wrote:
The fact remains that GM would not have spent 10's of millions of dollars on R&D if the original LB7/LLY block, pistons, rods and other things were "good enough" for the "same reliability". It wasn't.
When you beef up things like block casting and rod size they were worried about reliability. GM missed it when they went from a 150 HP N/A 6.2 to a 200 HP turbo 6.5. It showed. All of the main webbing started to crack up and reliability suffered terribly. They leaned a lesson in that engine and they didn't want to repeat that mistake.
This is not to say if you add a 60 HP tuner to a LB7 it will blow up? It won't. Will the reliability be the same or better than my LBZ? GM say's no way in hell and so do I.
โJan-10-2016 09:53 PM
โJan-10-2016 09:32 PM
โJan-10-2016 09:19 PM
Turtle n Peeps wrote:Grit dog wrote:
And about 90% of the problems with tuned trucks are guys wringing the guts out of them! The Dmax and Alli 1000 are virtually unchanged mechanicals for 15 years now but somehow it's ok to have a stock 400/800ish truck now but bumping up a truck with 530-650 tq will destroy it?
Say what? Virtually unchanged? Come on, here is a list of the stuff GM did to the engine when they added just 50 HP to the engine. (LLY to LBZ)GM wrote:
The comprehensive list of changes and upgrades to the 2006 DURAMAX 6600 includes:
* Cylinder block casting and machining changes strengthen the bottom of the cylinder bores to support increased horsepower and torque
* Upgraded main bearing material increases durability
* Revised piston design helps lower compression ratio to 16.8:1 from 17.5:1
* Piston pin bore diameter increased for increased strength
* Connecting rod โ I โ section is thicker for increased strength
* Cylinder heads revised to accommodate lower compression and reduced cylinder firing pressure
* Maximum injection pressure increased from 23,000 psi to more than 26,000 psi
* Fuel delivered via higher-pressure pump, fuel rails, distribution lines and all-new, seven-hole fuel injectors
* Fuel injectors spray directly onto glow plugs, providing faster, better-quality starts and more complete cold-start combustion for reduced emissions
* Improved glow plugs heat up faster through an independent controller
* Revised variable-geometry turbocharger is aerodynamically more efficient to help deliver smooth and immediate response and lower emissions
* Air induction system re-tuned to enhance quietness
* EGR has larger cooler to bring more exhaust into the system
* First application of new, 32-bit E35 controller, which adjusts and compensates for the fuel flow to bolster efficiency and reduce emissions
For just 50 more HP look what the engineers did to strengthen up the rotating assemble:
Block
Rods
Piston bore
Piston compression
All of this for just 50 HP. To say that this engine is "virtually unchanged" over the years is just not true.
โJan-10-2016 07:07 AM
This^
โJan-09-2016 04:41 PM
โJan-09-2016 04:20 PM
Grit dog wrote:Me Again wrote:racer4 wrote:
You can put larger tires on it. 265 instead on 245, same as the 2007 3500 came with.
Lots of people use air bags to level the truck, if needed.
I have a 2007 GMC Sierra Classic 2500HD and I did put on the same size tires as a 3500HD.
It will be gone soon.:(
Works well when you use the proper wider rims like the 3500 came with. Putting 265 on the stock 6.5 wide rims is not wise, as the sidewall really roll in. On my 2001 RAM it came with optional LT265/75R16's on 8" wide rims.
Chris
265s fit fine on the PYO wheels with no center tread wear from being too wide. Any bigger than 265s and the rims become too narrow.
I good cheap upgrade for the 16" rims are Dodge 3rd gen alloy 17" rims. They're 8-8.5" wide (I forget) and direct bolt up even the Chebby hubcaps. And they look 100x better, IMO. Can buy a set for a coup,e hundred bucks tops.
โJan-09-2016 02:29 PM
Chris
โJan-09-2016 10:05 AM
โJan-09-2016 08:49 AM
โJan-09-2016 08:43 AM
