โDec-12-2014 07:33 PM
โJan-13-2015 05:03 AM
โJan-13-2015 04:56 AM
JIMNLIN wrote:They can't? They certinly come close to it.
The trucks with highest payloads are RegCab 4x2s
Compare their base rear axle curb weights to rGAWR.
This was sent to a Car&Driver reporter from Ford and posted as part of their 2015 F150 review. Only the 4x2 2015 data was sent AFAIK.
The only 3300 lb payload I see shows a reg cab 2wd that has a rear base weight of 1843 lbs. Add the two gets us a 5143 lb which is a overload on the 4800 RAWR which is my point in my reply to redracer.
JIMNLIN wrote:
Looks like Ford dropped the 8200 GVWR package for a 7850 GVWR but kept the 4800 RAWR.
โJan-12-2015 05:59 PM
mich800 wrote:
I don't necessarily agree with that sentiment often noted on this forum. "get the bigger truck in case you upgrade trailers" Wouldn't that be the same as recommending purchasing a million dollar home because someday you might win the lottery.
โJan-12-2015 05:50 PM
โJan-12-2015 05:19 PM
wing-zealot wrote:
But seeing as we are talking about TT's, with 9500 lbs GVWR we are not talking about 3300 lbs of payload are we. No we are talking about F-150's, TT's, and 1200 lbs of payload. Go buy and F250 if you want, I don't need one.
โJan-12-2015 03:05 PM
โJan-12-2015 01:44 PM
โJan-12-2015 01:36 PM
cekkk wrote:
While this has been, emphasis on "has", has been an interesting thread, I'd offer this input. When looking to the truck's manufacturer for accurate and truthful numbers, they are not above marketing a light truck for its ability to pull the Space Shuttle. :S
Back to you techies.
โJan-12-2015 12:08 PM
TomG2 wrote:
Why get a 3/4 ton when a 1/2 ton will do? Most of us like trying new trailers every once in a while and it is nice to have reserve capacity in the tow vehicle. This park is full of experienced RVers and the only F-150's here were towed here behind a Class A motorhome. The large travel trailers and fifth wheels were towed here with 3/4 and 1 ton tow vehicles.
โJan-12-2015 11:18 AM
โJan-12-2015 11:06 AM
myredracer wrote:I don't know what you would buy. I would buy the tool that does the job and fits me. For a 9500 GVWR TT, I would buy a F150 with 2500 lbs of payload.
I get not buying a 3/4 or 1 ton for a pop-up or small TT, but what does one buy if shopping based on payload capacity for a larger TT you want to get? Why bother with a 3/4 ton with maybe 2700 lbs payload when on paper a new F150 would be much better for payload cap?
โJan-12-2015 11:02 AM
mich800 wrote:
Just to refocus this post as I think I may have missed something trying to go back 23 pages.
The problem stated is if you take a fresh from the factory truck and weigh it, subtract that from the GVWR that is not what is on the payload sticker?
โJan-12-2015 10:44 AM
โJan-12-2015 09:45 AM
wing_zealot wrote:
Your one size fits all doesn't work either. You don't need a 3/4 ton diesel dually to tow a popup. If a 1/2 ton is adequate, then you got one of the many proper tools that will work. I don't need to be force fed more than I want or need.
