Hybrid pickup by Workhorse
John___Angela
Interesting stuff
http://www.greencarcongress.com/2017/04/20170414-w15.html
Technically not really a Hybrid but a BEV with generator assist. 7.2 KW of job site power though. Handy. Towing is lite at 5000 pounds but its quick though. Kinda cool. Would probably work for a lot of contractors.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
22 REPLIES 22
rowekmr
Yes if it is shorter distance and/or more frequent charging I think it will be beneficial in theory.
I used to only charge at home but charging at work and at public stations my mpg are now 140 mpg.
mich800 wrote:
rowekmr wrote:
I always wondered why trains didn't have a dedicated battery car to recapture all that energy from dynamic braking. I didn't think the weight would be prohibitive since they have the capacity to pull so much.
Those bean counters at some companies will love the 75mpge of this vehicle. Our municipal cars routinely get horrendous single digits mpg's with all the stop and go and long idling. Another minor fact is less gasoline engine use means less oil changes and engine schedule maintenance per mile and with regenerative braking less brake pad wear. Lots of savings to be gained.
I would wait and see what the actual range on electric is. 80 miles per the article is a lot for a working truck. The Pacifica's I drive get about 40ish miles on a full charge. So in an eight hour day the average combined fuel economy is not really much better than if you got the regular six cylinder. But the smooth cvt and linear acceleration is worth it. If you are doing shorter commutes or have the ability to charge at extended stops the hybrid becomes more economical.
10 Lincoln MKS Ecoboost
07 Lincoln Navigator
00 Newmar Dutch Star 3851
mich800
mich800
BenK wrote:
And locomotives in the USA have been hybrids to this day....ever since they replaced steam locomotives
Guess those miles and miles long freight train hauling/towing rail cars are 'not' hybrids ????
**delete** quoted wrong post
rowekmr
BenK
Guess it depends which brand/OEM locomotive...know most of the GE diesel/electric locomotive have huge batteries
Did you guys know that the Submarines of WWII were diesel/Electric and ran on battery power when submerged ?? Huge batteries of that era
Yes, many of the other OEMs used large resister grids to dissipate the regenerated power during regenerative braking....most of the 'variable speed' electric controllers employed resister grids before the late 1960's and into the early 1970's and is when my startups made money converting them to solid state variable speed controllers
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
brulaz
They are not hybrids. They are diesel electric locomotives. They have no batteries so they won't move unless the engine is running. The electric aspect is for the transmission of power; it has nothing to do with battery power, regenerative braking, or emissions reduction as typical hybrid automobiles do..
They do use the use the electric motors for braking though. Reverse the current flow and use them as generators. But then just burn off the generated electricity in monster resistor packs.
Surprising they haven't yet gone to monster batteries instead of resistor packs. Maybe the weight is prohibitive?
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
John___Angela
Yah, and for us EV's drivers, that regen and the one pedal driving it brings is one of the things that would make it very hard to go back to a gas burner again. There is a long list of qualities that separate EV driving from ICE driving but this is one that you have to get used to everytime you step in an ice.
KD4UPL
WTP-GC
mich800 wrote:
Body designed by the Ford diesel department. Bet the oil filter is also easy to get to. 🙂
But it looks like they've already solved the problem of having to remove the cab for simple repairs 🙂
Duramax + Grand Design 5er + B & W Companion
SBGTF
Grit_dog
Navigator
Navigator
Groover wrote:
Dadoffourgirls wrote:
KD4UPL wrote:
GM offered a hybrid pick-up over a decade ago. It also included the ability to use it as a generator for on site power. I've worked construction for nearly 24 years and I've only ever known 1 guy who owned one. I think I saw a second one driving down the road once.
Apparently this isn't something there was a market for.
GM currently offers a hybrid (1500 Crew) with 5.3 and 8sp trans. Only available to order by California, Hawaii, Oregon, Texas and Washington eAssist Dealers.
I am not clear why GM dropped that earlier version but shortly after they did I read that they got horrible miles per gallon. It seems that they spent most of their days idling, serving as jobsite generators. I have wondered it that had anything to do with them being dropped. The Workhorse should do better in that application since it has a much more appropriately sized gas engine.
Or there wasn't a market for an overpriced, underpowered pickup truck that could be outdone by a normal pickup and a $1500 Honda generator.
Workhorse is an interesting concept for urban transit light duty work though.
John___Angela
And I think the traction battery is bigger as well.
Groover
RobertRyan
Hybrid aspect is the electric transmission a mechanical gearbox would be huge.
BenK
