I'm curios about the 6.7.
MSGTRETIREDCSP
Been sitting here in my 5th wheel today while it's raining outside.
I've been seeing some 2007 Dodge trucks for sale. Some have the 5.9 and some have the 6.7. If you were buying one, which would it be? The 5.9 or the6.7? Have you heard of any consistent problems with either one?
Not that I would ever consider changing brands.:W
2016 RAM Tradesman, 3500, DRW, 3:73, B & W hitch.
2007 Select Suites 5th Wheel
31 REPLIES 31
jerem0621
mtofell1 wrote:
Thread after thread of modern diesel engine talk is making me really think we are in the dark days of technology (or, more to the point, emission ****). The pre-DPF diesels are largely talked about as the cream of the crop. Pretty sad considering they are now 10 years in the rearview. Is there any light at the end of the tunnel?
I feel like 30 years from now the freeways will look like Cuba with a bunch of 2000-2006 Chevy/Dodge diesels rolling around.
We are just in a transition period. No worries...
Back in 94 when Ford went to the Powerstroke there was a lot of concern about the new "electronically controlled" Diesel. To the point where, at least in my area, there was a run on IDI Turbo Diesels the "Pre Powerstroke" that was mechanical with "no electronics to fail"... There were some teething issues with the Powerstroke but now it's the Gold Standard in diesels.
I am shy from the new diesels...I am waiting to see the technology mature...but I think it's going very well..DEF seems to be a major part of the solution for the trucks.
I am curious to see how the DEF trucks do after the warranty expires and we get some real age on these trucks.
As for power...we are in the glory days...400 hp and 800-900 lb ft of tq...glory days.
Same goes for the gas HD trucks...we have the best ones we ever have.
New trucks today are truly remarkable pieces of technology.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
mtofell1
4x4ord
If you're set on an '07 Ram I go with the 5.9 but if I was buying an old diesel pickup it would be an 06 or 07 Duramax.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
Grit_dog
Navigator
Navigator
It'll cost less to delete an early 6.7 than buy an exhaust brake for a 5.9.
I'd buy a 6.7 for the 6 speed auto but if going manual then a 5.9 would be preferable.
Overall, I'd shy away from early 6.7 Rams if you are opposed to deleting it down the road if you have recurring emissions problems. Seems 07.5-08 had more emissions issues than 09 up, they got it dialed in better just like the other mfg after a couple years under their belt.
Early 4th gen Rams are the same chassis and drivetrain as 3rd gen 6.7s with much improved cab/interior/amenities and with Rams new chassis and emissions in '14, they seem to he about the same price as late 3rd gens. I'd go for a '10-11 model if going used pre def Ram.
Hope they get your soon to be ex truck sorted out tomorrow........and economically!
Bionic_Man
You can add an exhaust brake to a 5.9. I had a Jacobs on my 03. I think in either 05 or 06 the 48RE transmission would work with one as well.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
drittal
What did we do before exhaust brakes?
How are we even still alive? (/sarcasm)
FishOnOne
Engine wise the 5.9 hands down.... Problem is the automatic transmissions were not known for reliability, but I would take my chances on it vs the early 6.7 with the emissions problems.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
YnotTurbo
I had the 5.9 in my 2004 dually. Great truck, but no exhaust brake. I have had 3 more since and love the 6.7. Current one has 900 lbs of torque..
Navy Chief (Ret.) Still working. 2019 Ford F350 Lariat, 4:10 Geared and 935 lbs. of Grunt..., 2011 Mobile Suites Lexington
garysol
LittleRedGoat wrote:
Mine is a daily driver also and have had severalroblems with emissions.
Makes me wonder if there was some other glitch that was causing the issue. Maybe colder weather not allowing the catalyst to get hot enough....etc....
2020 GMC Canyon
2022 NoBo 19.2
LittleRedGoat
2018 Chevy 3500 Duramax DRW, 4wd
2008 Dodge Ram 2500, 6.7l, swb, 4wd(old)
2013 V-Cross 295VRK
garysol
The 6.7 is not a grocery getter, it needs to be worked or you will have problems with the emissions
I drove my 08 daily..... short trips, long trips ....etc.... and it never ever missed a beat in 100k miles. My 14 now has 51k on it and I drive it the same also with zero issues......
2020 GMC Canyon
2022 NoBo 19.2
spoon059
If you are buying a mid 2000's Ram I would tell you to get the 5.9 CTD. The early 6.7 engines had some growing pains. The newer 6.7s with DEF and the redesigned frame are vastly superior... engine and the truck underneath it.
2015 Ram CTD
2015 Jayco 29QBS
LittleRedGoat
2013 V-Cross 295VRK
southernsky
If you're looking to buy a 2007 the 5.9 would be my choice. Had a 2007 3500 Megacab dually and only problem I had was the soot getting into my trailer through the slide seals. It was a good ole truck and did all the proper maintenance the book called for. Many trouble free miles and years. Now I have a 2011 with the 6.7 and 6spd auto tranny. Loved the ole 2007 but the 2011 is a whole different animal. Think I'll hold on to this one for awhile.
Oh and I'm not ashamed of changing brands, I use to be a Ford man.:B
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
SolidAxleDurang
I had an 07 6.7 for 9 years... No real problems at all... I bought a 15 6.7 as replacement.
Over the 5.9 it had the integrated exhaust brake... I loved it.
TV = 15 Ram 3500 Dually 6.7 / CC-LB / CTD / Aisin / 3.42 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 🙂 ) 14 Arctic Cat Wildcat 1000
