Feb-14-2019 12:16 PM
Feb-23-2019 11:09 AM
burningman wrote:
With the right fuel plate, delivery valves, injectors and turbos, you can make such stupid power that new stock diesel pickups are a joke... everyone is oohing and aahhing over measly 400-something horsepower while you have 700. It’ll cost you to build a transmission to handle it and some other upgrades so you don’t just scatter parts all over the street. But it won’t be $75,000.
And - it’ll run, period. No trouble codes, no check engine light, no DEF, no sensors, none of that garbage.
Feb-22-2019 07:57 PM
Feb-22-2019 07:04 PM
jimh425 wrote:
Besides, in your previous thread you said you were buying a new diesel when you retired? Has the 7.3L gasoline engine got you to switch back?
Feb-22-2019 04:22 PM
Feb-22-2019 04:20 PM
Feb-22-2019 03:35 PM
mountainkowboy wrote:
Sure a diesel might climb the hill faster than my gasser, but I'm in no hurry, so it doesn't matter and 9 grand buys a lot of gas. I cruise at 60 mph at 2,000 rpm getting 9.5 mpg on a 30 year old truck and I expect the newer gasser to get around the same.
Feb-22-2019 02:54 PM
Feb-22-2019 11:25 AM
Feb-17-2019 07:52 PM
Kayteg1 wrote:pnichols wrote:
I wonder when (if ever) trucks are going to have solenoid operated valves?
Closing both intake and exhuast valves automatically whenever needed on downgrades would probably provide very powerful compression braking in gas engines.
Even in build for high pressure 6l Powerstroke the cylinder pressure could lift the heads in extreme situations.
I can only imagine what that idea would do to gasoline heads who were never intended for high pressure.
Feb-17-2019 07:38 PM
Feb-17-2019 07:10 PM
Feb-17-2019 06:54 PM
Feb-17-2019 06:51 PM
Kayteg1 wrote:Glad technology has moved us past the need to butcher DPF's--lol! Seriously though, it's good to know there are other options available if/when a DPF fails. Thanks.otrfun wrote:That would be technique used by butcher.
... FWIW, I've heard you can get a DPF cut-open, cleaned, and welded back together for about a 1/3 the cost of a new one.
DPF cleaning follows up the technology and now in any bigger US city you will find a shop who does ultrasonic cleaning.
In Europe they have several different techniques - from plain water pressure flushing to use of solvents . . .
Feb-17-2019 05:41 PM
