โMay-01-2014 06:44 PM
โMay-03-2014 02:21 PM
smkettner wrote:
Install a small inverter behind the main fuse/breaker panel. Wire to the existing 120v circuits and you have power where needed.
โMay-03-2014 06:49 AM
โMay-03-2014 05:36 AM
dadwolf2 wrote:
I think it's a good judgement call!
โMay-02-2014 11:50 PM
โMay-02-2014 08:52 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โMay-02-2014 08:03 PM
JimBollman wrote:
I have installed using existing wiring and also ran new wiring. The problem with existing wiring is it is usually to light if it is handy and even if you think your only going to use light duty someday you will want to plug something heavier in and then you will have problems.
My latest installs was a 3 outlet manifold mounted close enough to the battery that I could run new heavy wiring through a dedicated fuse to the battery. I also installed a dual USB plug which can be put in to existing wire since you know that you can't pull to much power. I liked the one MM used but I went with a BlueSea close to the bed so I could charge my smartphone and read a book on it while in bed.
โMay-02-2014 05:47 PM
โMay-02-2014 12:10 PM
โMay-02-2014 11:19 AM
โMay-02-2014 08:42 AM
hedge wrote:
Thanks Mello Mike, it was your blog post that originally got me thinking about adding the outlets. I like that one you used but it would be spendy to get it delivered here.
โMay-02-2014 06:48 AM
โMay-02-2014 04:39 AM
Reddog1 wrote:
Perhaps I overlooked the amp rating of the outlets posted, but my experience is that the typical source of outlets are 5 amps. Using the Marine quality outlets usually have a higher amp rating. I will also add, if the outlet packaging does not indicate the amp rating, it is most likely 5 amps. This is important to know for wire size and the fuse.
Wayne
โMay-01-2014 11:37 PM
โMay-01-2014 10:08 PM
Toad: 91 Zuke
