โJul-22-2016 12:29 PM
โAug-15-2016 06:24 PM
Muddydogs wrote:
From my experiance diesel in a gas truck or gas in a diesel doesn't just kill the truck or cost thousands to fix like auto dealers like you to believe. Out of probably a dozen pickups that have had the wrong fuel put in them all I have ever had done was draining the fuel tank of the wrong fuel and refilling with the right fuel. If the mistake was caught after only pumping a few gallons the tank is just filled the rest of the way with the right fuel and kept full for a few 1000 miles to dilute the wrong fuel as much as possible.
I deal with this at least once a summer.
Fordlover wrote:
We used to get these at the Ford dealership simi frequently. Seems like they were mostly company vans/trucks. The thing that sucked was the 40 gallon tank would be full of the wrong stuff, so you had to find a place to store 40 gallons of contaminated fuel, then pull the tank and clean. Never did any damage that I can remember, but those were the 7.3/6.0 diesel days, long before the sensitive Bosch fuel pump.
โAug-03-2016 05:28 PM
โAug-01-2016 10:54 PM
greende wrote:icanon wrote:MitchF150 wrote:
I thought the diesel nozzle is larger than a gas nozzle, so it wouldn't fit anyway?
Mitch
X2 ?
Around here they are only bigger at truck stops. The regular gas stations here have the same size nozzels for both as many people have Jettas etc that burn diesel.
โAug-01-2016 12:31 PM
โAug-01-2016 06:56 AM
โAug-01-2016 06:03 AM
bbaker2001 wrote:
when we were in Ireland, we had a diesel rental.. pulled into station, grab the green handle and started pumping. a man asked if I knew I was putting regular gas in my diesel car. I said it has a green handle. He said I must be an American. over there it is green for gas. opposite from us.
โJul-25-2016 12:35 PM
โJul-25-2016 07:20 AM
โJul-25-2016 04:33 AM
โJul-24-2016 05:27 PM
โJul-24-2016 04:57 PM
โJul-24-2016 03:28 PM
Mitch
โJul-24-2016 11:31 AM
โJul-24-2016 09:19 AM
