lifted truck?
Buzzardcheater
Hey all - soon to be making the shift to a TC, and that starts with upgrading my truck. I'm looking a getting a used dually, and one I'm checking out is lifted by several inches. It's running 18 inch wheels.
So - question for the assembled wisdom here: Does the lift pose any structural, suspension, or comfort issues when I put a large TC on the back of it? For the record, I'm trending toward a Lance 1172 (so,yeah, heavy)
Thoughts?
2017 Lance 1172
2016 Chevy Silverado 3500 HD DRW diesel; airbags, torklift tie downs, superhitch
2013 Jeep Wrangler JK
23 REPLIES 23
Otterman
I'm curious, those of you with stock Fords and Dodges. How high is your bed from the ground?
2015 Chevrolet Silverado 3500HD, 4.5" BDS lift, BFG AT/KO2 285/65R20
Vision Hauler 19.5s and Toyo M608z 285/70R19.5 for camper duty
2016 Arctic Fox 990
2BLAZERS
So how lifted is it?
18'' wheels does not effect anything as its the tire size that matters.
My 2011 Dually had a 3'' leveling kit and Supersprings on the rear also brought up the rear. I had no issues with it. Looking at doing the same on my 2016 dually.
I personally wouldn't do much more than a leveling kit if I was hauling a truck camper and or towing a large trailer.
On a SRW with a lighter camper or popup camper I could see doing a 4 to 6 inch lift on it for fitting larger tires for offroading.
So far in life my 2016 is the only truck I have owned that has not ended up being lifted or leveled out 🙂
2016 Dodge Ram 3500 CC Dually Cummins,Aisin,Laramie,4*4,4.10,14K
2017 Stealth WA2916 Toyhauler
2011 Arctic Fox 1150 Drybath
2017 Polaris 1000 XP Sportsman
2009 Polaris RZR w/fun parts
2014 Polaris 850 HO Scrambler
1977 K5 Blazer 1ton'd
2005 Pace Enclosed Toybox
Travelon
jefe 4x4 wrote:
The answer is not cut and dried. I mostly depends on what terra you are driving on. For most TC owners, the stock suspension height is just the ticket. A stock suspension is a LOT less trouble than any lifted, clabbed together one. This only changes if you are an XTC-er. I have a Gen2 Dodge which has a lot of clearance below the frame in stock format. Once I started using the TC like I used various 4WD's I've owned, I found I needed a little more clearance on the approach angle, the breakover angle, and the departure angle. Having a short bed helped in the last two angles but I installed 3" lift coils on the front axle, which, of course forced me to level things out by going with 8 leaves on the rear axle giving that 3" lift to the rear also. (5 leaves in the main pack and 3 leaves in the upper secondaries). The extra on the rear axle was it was stiffer and less apt to sway. On a trip up Goler Wash in Death Valley this past Spring, I used every bit of that clearance just to get over the trail.
Very stable, but I have an under 2000 pound wet camper with the lowest ceiling height, so only 10', 4" tall, overall. If i didn't enjoy 'the edge' while TC-ing, I would want a stock suspension setup with no lift.
I'm thinking you are in the 'normal' range of would-be TC-er's, so an unlifted truck should be your goal. jefe
Jefe4x4 is truly the 'Captain Kirk' of TC-ers "To boldly go where"...well you know the rest.
Travelon
2004 Silverado 2500HD D/A CC LB 4x4, Timbrens, Fold-a-Cover,
Line-X, DeeZee Running Boards, Prodigy, Husky 16K UBS,
2004 Titanium 32E37DS, Two Honda EU2000i
jefe_4x4
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
billtex
Most of us modify our suspension for load carrying capacity (stiffer). "Lifted" trucks are typically for off-road applications-more compliant (softer) suspension.
Not what you need for heavy hauling.
I would pass on this one...
Bill
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
James_
Remember, a Lance 1172 weighs A LOT!
Lance 1172: dry weight, 3,923 pounds + 42 gallons fresh, 350.3 pounds + 6 gallon full hot water heater, 50 pounds + 2x 30-pound full propane tanks, 54 pounds + 2 batteries, 130 pounds + stuff, 500 pounds = 5,007.3 pounds.
2006 Chevrolet 3500 HD 4X4 dually, crew cab.
6.6 diesel, Allison trans. Air bags.
2011 Lance 992 duel pop-out, 2200 gen, 135 watt solar panal, Yakima skybox.
_DJ_1
Buzzardcheater ~ Love your handle!!
From a guy with a lifted truck, 4" suspension and 35" tires, a lifted truck would not be ideal for normal camper hauling duties. As mentioned, softer springs for better articulation and the taller height creates more of a roll tendency. I get away with it as I only have a small pop up.
I would especially be aware of a lifted dually. For larger rear tire clearance one would need spacers, very hard on lug studs and bearings.
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
Ski_Pro_3
My Lance 855S can be lifted to a maximum of 45" from the ground to the bottom of the camper. My truck's bed is 42", giving me 3" of clearance if I go all the way up. I usually only go 1 1/2" higher than the bed in order to clear and set the camper in or take it out.
discovery4us
Also depends on the truck. My current toad is a Chevy 2500 W/ 4" lift and 35" tires and I am the same height as a stock Dodge Ram 2500 on a good day. While I don't have a camper for this truck I wouldn't hesitate to put one in it and head cross country.
Not necessarily a good comparison but I carried a Lance squire light in the bed of a lifted Chevy 1500 and never had issues. Moved up to a lifted F-250 and life was even better so it can be done and can be done safely.
Bedlam
Moderator
Moderator
Artum Snowbird wrote:
The other item is your steps in. Some use platforms to put the lower step on, but even then, getting the scissor steps to work well when there is a lower back end to put the steps on is really difficult and dangerous at times. Family and dogs coming up and down sloping steps is not fun.
Torklift GlowSteps and GlowGuide are very adjustable. Torklift even made me a heavy duty 7-step version of their 8" tread to allow GlowSteps from the door opening instead of using a basement step. With the LandingGear on the end of the steps I even adjustment when the truck is blocked level on a side slope. SafeSteps give my DW additional confidence in climbing the seven stairs to the door even though she already has a hand rail.
mkirsch
Nomad II
Nomad II
mooring product wrote:
I had a F250 with 4" and 35" tires. It was a pain to load and unload the camper.
I ended up installing 33" tires.
1" of height made a noticeable difference?
Before someone points out that the tires are 2" shorter, let me point out that the distance that matters is between the hub center, aka the middle of the tire, and the ground. HALF the diameter of the tire, aka the radius. 2" difference in diameter is 1" difference in radius, thus 1" difference in overall height of the vehicle.
Grit_dog
Navigator
Navigator
A couple of things to start.. Likely your jacks will be at full extension, or even up on blocks in order to remove or remount your camper. That can be OK when on pavement, but if you plan to remove the rig at your destination in a campground, you have to be extra careful with having a stable flat surface to put the jacks on.
Yeah, so a dually would probably still haul it fine...... But if you haven't had a lifted truck before, you'll go thru steering and driveline parts quicker. Yes it will roll more, but plenty of camper s on jacked up trucks, although not my first choice. And height may be an issue.
My srw stock suspension ram is tall enough that I almost have to max out the jacks to load it. If it had even a 4" lift and 35s I'd have to put blocks unsolder the jacks to get the camper up enough to load.
mlts22
Buzzardcheater wrote:
... and this, ladies and gentlemen, is why I dig these forums. Quick responses to my question with a lot of good insight. y'all confirmed some of my concerns and I'll keep hunting for a non-lifted truck.
Very wise. I also live in Austin... and even though truck prices are high, there are many, many non-lifted trucks to choose from.
mooring_product
Pete
2012 RAM 3500 Mega DRW. Stable Loads and Torklift tiedowns.
2006 Lance 881 Max.
