Jan-14-2021 06:14 PM
Jan-16-2021 06:40 PM
TomG2 wrote:wilber1 wrote:
What vehicle? What engine.
Read it on a Ford Forum where is was mentioned as a matter of fact with Ecoboost engines. People were saying things like, "I towed 1,800 miles and only "Gained a small amount of oil". The reason I am not mentioning engine and vehicle is that it was not me that reported the gain. I wondered if others had heard of this.
Jan-16-2021 02:15 PM
wanderingbob wrote:
I was taught to check oil when it was cold for an accurate reading ?
Jan-16-2021 09:32 AM
Jan-16-2021 02:38 AM
dodge guy wrote:
If you are talking gas motors like the eco boost. They run hot and the oil can and will expand appearing over full. This is why it's best tomch ck it in the morning before you start it. This goes for any motor.
Jan-16-2021 01:39 AM
Jan-15-2021 08:35 PM
TomG2 wrote:
I see on another forum where owners report of showing more oil on their dipstick at the end of a long hard drive than at the beginning. Mostly with turbocharged engines. Anything to this or explanation?
Jan-15-2021 07:51 PM
Jan-15-2021 02:53 PM
Jan-15-2021 08:21 AM
Jan-15-2021 07:52 AM
NRALIFR wrote:It is. I'm not sure if the shop where I had it replaced could do that or if it actually needed to be replaced. I seem to remember they said it was a goner.. and at only 100k miles. Anyway, it was expensive.
Do you know if the DPF on yours is designed to be taken off and cleaned?
Jan-15-2021 07:44 AM
Jan-15-2021 07:26 AM
NRALIFR wrote:Yes, 2008 Cummins 8.3L. I don't think my regen is working properly. Next shop visit when spring returns. It's very tempting to want to delete this thing, but... oh well
You have a Freightliner, right? Maxxforce powered?
Jan-15-2021 07:13 AM
2oldman wrote:NRALIFR wrote:That's what I have, and this truck does not go grocery shopping.
That’s a very common problem on Diesel engines that were manufactured from about 2007-2010. They typically had diesel particulate filters (DPF), but did not use diesel exhaust fluid (DEF).
Jan-15-2021 06:59 AM
NRALIFR wrote:
That’s a very common problem on Diesel engines that were manufactured from about 2007-2010. They typically had diesel particulate filters (DPF), but did not use diesel exhaust fluid (DEF). They relied heavily on exhaust gas recirculation (EGR) to control oxides of nitrogen (NOx), and as such, cleaned or regened the DPF frequently. Sometimes as often as every 75 miles or so.
Most, but not all, of the Diesel engines of that era started the regen process by over fueling the engine on one or more cylinders, causing unburned fuel to flow into the exhaust where it would then be ignited inside the DPF. That over fueling also caused fuel to get past the rings into the crankcase, and is what resulted in the engine “making oil”.
I had one of those engines in a 2010 F450, the 6.4 L Powerstroke. I absolutely loved everything about that truck, at least initially. I learned to absolutely hate the engine though. I owned it for a little more than three years, and I always drained out about a quart more oil than I put in. Top-end valve train failures were an issue with those engines, though I never experienced that myself.
Ford had a TSB for the 6.4’s to check for excessive fuel in the oil that involved pulling the dipstick, wiping it clean, then replacing it just to the point where the plastic pull ring at the top of the dipstick started. That was at least an inch higher than if you fully seated it in the dipstick tube. As long as the oil level wasn’t higher than the top line on the dipstick, all was supposedly good and there was nothing to worry about.
I got rid of that truck before it caused me much financial pain.
Jan-15-2021 06:36 AM
