โNov-14-2020 09:15 AM
โNov-22-2020 12:24 PM
JIMNLIN wrote:
However some LED brake lights are so bright they make turn signals almost impossible to see depending on the where the turn signals are located w/i the fixture.
โNov-22-2020 11:44 AM
โNov-21-2020 09:49 PM
Durb wrote:
My post is perfectly clear to anyone except those that choose to be only argumentative. I offered information to the OP that I thought was pertinent to his post. Trying to translate my comment on brake light illumination times to marker lights is just childish.
Time for some numbers in an ongoing effort to help the OP which some have no interest in doing. Delphi estimates 37% to 74% of rear end accidents could be eliminated with a 500 millisecond early warning. LEDs light up 200ms faster than incandescent. This translates to 19.1 feet at 65 MPH. I'll take a truck's length safety margin by changing lights to LEDs every time.
โNov-21-2020 09:27 PM
โNov-21-2020 09:00 AM
โNov-18-2020 12:18 PM
โNov-18-2020 11:31 AM
โNov-18-2020 10:43 AM
โNov-18-2020 10:21 AM
aftermath wrote:
I am glad that you learned your first grade lesson. If you were to have made it to a high school English class you might have also learned that writing should be clear and concise, factual and compelling. There is room for subtly, but that should never be used an informative forum like this.
โNov-18-2020 07:46 AM
โNov-18-2020 07:14 AM
โNov-18-2020 06:34 AM
Bumpyroad wrote:deltabravo wrote:Bumpyroad wrote:
so your marker lights work as stop lights?
No,Marker lights aren't stop lights. No where in his post did he say anything to that effect.
here
I changed out my marker lights and found nice ones with correct hole spacing on superbrightled.com. I read once about the light-up time of LEDs compared to incandescent; the LEDs were milliseconds quicker which really made a distance difference when going 70 MPH. May keep you from getting hit from the rear as the LEDs light up faster.
I just replaced the cab clearance lights on my truck to LED. They look good and are definitely brighter.
If I was worried about folks rear ending me, I think I would easily install some large LED center and eye level light and not worry about the "marker" lights.
bumpy
โNov-18-2020 05:33 AM
โNov-18-2020 05:17 AM
