mpg towing
whsk
just finished a 2588 mile trip pulling about 12000 lbs. (5th wheel)DW kept track and here is the low 9.4 and high 11.9-2013 Dodge 3500 4x4 with 6 speed stick-truck did a very good job-I was impressed!overall avg. was 10.6-whsk
30 REPLIES 30
panthercity
Me Again wrote:
BB_TX wrote:
Those numbers are just about dead on with what I have gotten pulling my 35' 5er, both with my previous '07 F350 6.0 and my current '12 F350 6.7 running at posted speed limits on the highways (up to a max of 68-70). Could probably do a little better if I slowed down to 60-65.
The is a bit disappointing! These trucks are getting better and better in so many ways except for fuel mileage. In the early 2000's it was common for Duramax GM's, 7.3 Powerstrokes and Dodge/Cummins to deliver towing mileage in the 12-13 MPG range.
Are people just all towing to fast with them now? I tow at around 62-63 MPH most of the time and average 12.2 to 12.5, and can be as high as 13.5-14 in central California at 59 MPH on flat no wind legs.
I was hoping that the new DEF RAMs would be back up in that range!!!!
Chris
That was before USLD in 2006. Then GM changed their emissions systems to burn the particulate by injecting extra fuel whenever the particulate trap got full. That and new/different tuning impacted mileage significantly.
RedJeep
2001 f350 7.3l 4.11 w/ 40' Cyclone at about 15500 pounds. I get about 9.5 mpg around 58 mph on rolling hills in the Northwest. In the steep mountain areas I get about 8 mpg.
However, when I average overall fuel consumption with commuting on my motorcycle I can claim that between the truck and motorcycle I get over 20 mpg!
๐Ÿ™‚
2008 Georgetown DS350 Class A
Wife, kids, dog and cat
PartyMarty
That mpg sounds good to me .
I only have 520 # of torque.
If I had 765 # of torque I would use it .
I already tow too fast .
So my mpg would suffer , anyway .
Thank you for the info .
Thomas_NH
dbbls wrote:
The new trailers are getting larger and heavier also.
Not true... I had a 2010 Keystone Sprinter 297RET (34'w/2 slides), traded it for a 2013 Cougar High Country 321RES (35' w/3 slides) and lost 1000 lbs... The new one has more room, its better built with the Helium technology, has an extra slide, it tows better and it gets better mileage (2+ mpg better due to the aerodynamics). They are building them better and weighs less.
whsk
truck is a dually with 3.73 gears-9.4 was strong headwinds and 11.9 no wind-from pa to az mostly on I-81 and I-40-truck did a good job-could run as fast as I wanted to-had to watch myself ha-ha!-whsk
Old-Biscuit
Pretty much what I get with my '07 Dodge and 14K 5'vr
dbbls
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
hone_eagle
The compression ratio's have been inching down bit by bit for a while now ,that and all the other measures to reduce NOX have hurt efficiency .
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
BB_TX
Chris- My only experience with the new truck was a 2,000 mile trip to CO and NM last June. Part was mountains and almost every day was high winds. That plus the fact I generally ran at/near 70 on the interstates likely dropped the mileage quite a bit. Would probably be considerably better at 60 on flat highways and no wind. I just have a problem keeping below 65. :S
Me_Again
Chris
BB_TX
Me_Again
Is that a DEF model truck??? More details on the truck would be good!
With a similar size trailer, I get almost 2 mpg better. Chris
Turbo_Diesel_Du
Just pulled our 34ft 9K TT down from NC yesterday and got from 10-11.5 @ 62-65 mph. 2012 Ram 2500 CC 4X4 6spd auto. Quite a few grades from Marion,NC to SC and 95. Only been in the shop from 16th July to yesterday. Didn't want them to hurry or anything. (Make a note of sarcashem (?)
charles weidman
spoon059
That's pretty good for a 1 ton pulling a fiver. My Tundra 5.7 pulling a 7000 lbs bumper pull gets about that mileage. Your weights are close to double mine combined and same mileage.
2015 Ram CTD
2015 Jayco 29QBS
dave17352
What speed did you cruise at on the highway?
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
