โJul-09-2021 06:14 PM
โJul-12-2021 10:47 AM
โJul-12-2021 09:50 AM
โJul-12-2021 08:54 AM
โJul-11-2021 07:27 AM
โJul-11-2021 06:56 AM
โJul-11-2021 04:10 AM
โJul-11-2021 12:00 AM
MN Ben wrote:jimh425 wrote:
Looks to me like the DRW brackets are installed wrong. They should be parallel to the TC sides, but appear to angled toward the cab.
Btw, itโs normal for the TC to move side to side some. You just have minimal clearance.
When I originally had these brackets one was angled in and the other was flipped and more inline with the camper side. I needed all the clearance I could get so I flipped the one. This made the jack straight out when unloading giving me the most clearance and angled towards the cab when folded in. I actually made the 3" extensions to give me more clearance. Maybe now I could try the brackets reversed. Maybe.
โJul-10-2021 11:42 AM
โJul-10-2021 08:19 AM
โJul-10-2021 08:11 AM
MORSNOW wrote:
Your issue shows the big weakness with TorkLift tie downs. The anchor points are almost vertical with most trucks/campers so they don't hold the camper from dancing around in the truck box (left/right, front/back). You need more triangulation to hold the camper from moving any direction in the truck box. HappiJac gets beat up here many times, but their holding angles are far superior and your camper stays put.
โJul-10-2021 08:01 AM
MN Ben wrote:
I originally thought this was from my camper. I have absolutely no clue. I made a video in hopes someone would know what caused this. https://youtu.be/djhJfPwoNlA
MNBen
โJul-10-2021 06:13 AM
MN Ben wrote:silverbullet555 wrote:
Your trailer is rocking back and forth in the bed which is independent of the cab, or the cab is rocking back and forth. In either case, the body bushings are where it's likely rocking and it is moving enough to make contact. Could be cab is moving one way and camper the other on rough roads, over bumps, etc.
Even with the Fast Guns attached? It happened on one side but not the other.
โJul-10-2021 04:56 AM
โJul-10-2021 03:55 AM
