Jan-06-2016 07:01 PM
Jan-09-2016 09:20 PM
Jan-09-2016 09:11 PM
Jan-09-2016 05:25 PM
v10superduty wrote:blofgren wrote:
I bought my truck with long term ENGINE reliability in mind which the Cummins has a pretty impressive record of.
:B
Here, I fixed it for ya.. Added the word (engine) for you
That makes your comment accurate and believable.
Most every fleet owner and educated individuals know that the Ford chassis holds up the best and has the lower operating expense over the long haul.
Jan-09-2016 12:56 PM
:B
Jan-09-2016 12:42 PM
:B
Jan-09-2016 07:52 AM
Jan-08-2016 09:23 PM
blofgren wrote:FishOnOne wrote:davidaf wrote:Cummins12V98 wrote:
Did you test drive a LongHorn? If not IMHO the seat/driving comfort is awesome.
It wasn't so much the actual "Seat" that was uncomfortable it was the way the truck drove. Couple things that stood out: The powerband is different so take off/acceleration felt a bit softer, ride felt stiffer, EB seemed louder and didn't seem to slow the unladen vehicle as quickly or stay active as long (mind you i'm comparing a 4.3 to 4.1). Last year when I drove the 15 Ram it seemed a lot louder, i was surprised how much quieter it seemed the other day so that has moved down on my issues list. Interestingly the truck felt lower and had more visibility over the hood. Again these were my observations/opinions. It may differ from others experiences/opinions. Almost forgot the mirrors, Ford does make some good mirrors.
I agree the cummins feels anemic loaded and unloaded when compared to the Power Stroke that really pulls strong like no other.
Also I believe Ford didn't mess with the Super Duty platform is because it simply was and still is the best platform out there. The other big 2 have finally caught up and one has literally copied the Ford front suspension because of inherent problems.
BTW... This is coming from a long time GM fan.
Fish, have you actually driven a newer Cummins loaded? They are FAR from anemic. The Cummins was not built for drag racing; it was built for towing which it does extremely well. The fact that the 6.7L Powerstroke can climb a hill slightly faster means absolutely nothing to me and I would be the majority of owners who pull with these trucks. I bought my truck with long term reliability in mind which the Cummins has a pretty impressive record of.
And if the Ford is still the best platform out there why would they bother bringing out a new design? :R You really need to take off those blue goggles! :B
Jan-08-2016 09:17 PM
Jan-08-2016 09:12 PM
ShinerBock wrote:
So would it make you feel better if they just they just took the F450 badge off and replaced it with an F350 badge? Although I would have to ask what would be the difference between doing that and what you are saying since they both have the same outside dimensions? Is it because one badge says 3 and the other says 4, and you wouldn't be the coolest kid on the block unless you had a 3 on the side of your door?
The number on the door does not mean a thing when it comes to a set standard that manufacturers have to abide by. There is no law on the books saying that all 350/3500 trucks must be with X towing or X payload. A manufacturer can give of their models any numbers they want. Hell, tomorrow Ram can slap a 1500 badge on the side of their 3500 trucks and call them 1500s from now on. There is no law stopping them from that nor is their one saying certain model numbers have to mean certain tow limits which is why Ram is able to give their 3500 a tow limit that used to only be pulled by medium duties.
If you have a problem with this then do you take issue with Ram on it's 1500? Ford and GM both have 150/1500s rated to tow over 11,000 lbs. You would have to get a Ram 2500 to be able to tow that kind of weight in a Ram because their 1500s are not rated to tow that much. You basically have the same scenario here where Ram has to get a higher numbered truck to tow what GM and Ford can with their lower numbered truck. Now, you may be telling yourself that a 1500 shouldn't be towing that kind of weight and is a better job for a 250/2500, which I would agree. Well, maybe Ford thought the same thing with a 350/3500 heavy-light duty truck towing 30,000 lbs so they derated their medium duty F450 to do it.
Also if you really want to get into it, some F450 chassis/cab variations have a 16,500 GVWR which makes them a class 5 truck. I wonder if those guys driving those F450s get mad because they don't have an F550 badge on their class 5 truck? Heck, you can even option to have your F350 derated to 10,000 GVWR which technically makes it a class 2B three quarter ton but with an F350 one the door.
Jan-08-2016 08:58 PM
Jan-08-2016 06:55 PM
Jan-08-2016 05:58 PM
Jan-08-2016 05:35 PM
Jan-08-2016 01:03 PM
Jan-08-2016 07:20 AM
ShinerBock wrote:Rangerman40 wrote:
I actually own an F250...... Just don't like the way Ford is going about this. The only way they can compete with RAM is to derate a larger vehicle to fit within the class 3 specs instead of making the F350 a more capable truck.
The number on the door does not mean a thing when it comes to a set standard that manufacturers have to abide by. There is no law on the books saying that all 350/3500 trucks must be with X towing or X payload. A manufacturer can give of their models any numbers they want. Hell, tomorrow Ram can slap a 1500 badge on the side of their 3500 trucks and call them 1500s from now on. There is no law stopping them from that nor is their is their one saying certain model numbers have to mean certain tow limits which is why Ram is able to give their 3500 a tow limit that used to only be pulled by medium duties.
If you have a problem with this then do you take issue with Ram on it's 1500? Ford and GM both have 150/1500s rated to tow over 11,000 lbs. You would have to get a Ram 2500 to be able to tow that kind of weight in a Ram because their 1500s are not rated to tow that much. You basically have the same scenario here where Ram has to get a higher numbered truck to tow what GM and Ford can with their lower numbered truck. Now, you may be telling yourself that a 1500 shouldn't be towing that kind of weight and is a better job for a 250/2500, which I would agree. Well, maybe Ford thought the same thing with a 350/3500 light-heavy duty truck towing 30,000 lbs so they derated their medium duty F450 to do it.
