Jan-21-2020 09:05 AM
Feb-11-2021 02:29 PM
ticki2 wrote:Kayteg1 wrote:
The tires on my F350 dually give it 18,000 lb capacity.
Rear axle was derated from what I heard. so taxable 14,900lb is way below actual capabilities.
That still doesn't show their knowledge about TC use.
Please post the stock tires and wheels you have on your f350 drw thatt are rated at 4500 pounds each in dual application.
Feb-11-2021 02:27 PM
Feb-11-2021 02:15 PM
Feb-11-2021 01:13 PM
Feb-11-2021 11:55 AM
Feb-11-2021 11:37 AM
Feb-11-2021 11:26 AM
Feb-11-2021 09:54 AM
Feb-11-2021 09:35 AM
Fish mojo wrote:
What type of payload rating are you seeing for F350 SRW Lariat with the 7.3/ 4.30 gear combination? I’d like to get rid of my class C MH and get a non-slide TC. I really like what I read about the new Lance 960 or Cirrus 920 or AF865. All of these will push 3000 plus dry weight. Doable with the 7.3 SRW?
Feb-11-2021 04:22 AM
Feb-11-2021 03:27 AM
Feb-10-2021 08:40 PM
Feb-10-2021 07:26 PM
Feb-10-2021 08:14 AM
egarant wrote:Kayteg1 wrote:egarant wrote:
I pulled out the Truck Camper Specification sheet for both trucks:
2013 RAM 4,784 lbs
2021 FORD 5,071 lbs
So the FORD gains me overal 666 lbs in cargo capacity which includes 287 lbs of truck camper carrying capacity
That is due Ford switching in 2017 to aluminum beds and heat-treated frames, what saved about 500lb from truck weight.
Nothing to do with engine.
Talking about huge HP in newer engines - you can't use it if you can't cool it. Gas engines produce about twice the heat diesels do.
FYI the entire truck body, not just the bed is made of aluminum. I was shocked on how light the hood was compared to my RAM.
Feb-10-2021 06:56 AM
