New to us TV overheating??
campincory
We recently bought a new to us TV. It is a 2004, 2500HD Silverado w/ the LLY Duramax. We been on three camping trips with it so far. I absolutely love the truck. It is my first diesel and cannot believe the difference in towing. Here's my issue. When we go up hills, the fan comes on like it's overheating. The gauge is straight up in the normal range. I'm not sure if the fan clutch is going out, or if is normal for the fan to come on like that.
Any help would be greatly appreciated.
2004 Chevy Silverado 2500 HD Duramax/Allison
2007 Coachmen Chaperrel 5th Wheel
13 REPLIES 13
45Ricochet
jaycocamprs wrote:
What you have is normal for a LLY. I know, I have one. What is happening is normal for all trucks, work the engine on a hot day the fan cools things off. But the 04 & 05 LLY trucks have a cooling capacity that is only marginal, the 06 trucks have a 30% larger radiator. So the fan comes much sooner and at lower ambient temperatures. And worst of all, the fan won’t even hold the temperatures in check on a long hard pull. We bought our 05 because we wanted to buy a trailer like we now have, and knew our 6L gas 2500HD was enough truck. What we got was a truck that couldn’t do the job on a 100 degree day. Like ib516 said, go to the Diesel Place and read. Then get one of these.
We put on of these Ron Davis made auxilery radiators in our truck (the picture is not mine) and have not looked back.
Thanks for your input! Some just don't understand SW heat in summer, brutal.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
jaycocamprs
What you have is normal for a LLY. I know, I have one. What is happening is normal for all trucks, work the engine on a hot day the fan cools things off. But the 04 & 05 LLY trucks have a cooling capacity that is only marginal, the 06 trucks have a 30% larger radiator. So the fan comes much sooner and at lower ambient temperatures. And worst of all, the fan won’t even hold the temperatures in check on a long hard pull. We bought our 05 because we wanted to buy a trailer like we now have, and knew our 6L gas 2500HD wasn't enough truck. What we got was a truck that couldn’t do the job on a 100 degree day. Like ib516 said, go to the Diesel Place and read. Then get one of these.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
N-Trouble
nremtp143 wrote:
Also keep in mind that the gauges in all of our trucks are just IDIOT lights. Meaning by the time they move, something is really wrong. If you want to really know what is going on with the truck, buy a gauge like the Edge Insight CTS #83830 here Edge Monitor IT will show you exactly what the truck computer is seeing and takes out the "wonder if everything is ok" questions. You watch the info in real time. By the time most gauges show a change, damage to your truck has probably occurred. It will monitor several parameters at a time and you can check it at a glance. I love mine..This is NOT a programmer...a monitor only.
What he said... THe engine temp gauges on the GM trucks are known for being very innacurate. You can get accurate readings but don't need to spend the coin on an Edge Insight to do so. If you have an Android based SMART phone you can download the free Torque app and pick up an OBDII ELM bluetooth transmitter off of ebay for around ~$20 that plugs into the OBD port (below dash) and will give you accurate water temperature readings.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Hamops
The first time that I heard the fan kick in on our Dmax, it scared the living daylights out of me. I initially thought that there was something wrong with the engine but I shortly realized that everything was ok. It's good thing that the fan isn't going all the time because you wouldn't be able to hear yourself think inside the cab. I have even noticed that the fan will kick in on a long downgrade. Why; I'm not sure, but I think that it's adding negative horsepower to assist in slowing down the truck and trailer.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2014 Avalanche 295
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera
Norskeman
Normal condition on the truck.
X2 on the edge insight CTS. Have one - always good to see how hard the engine is working - boost, EGT, engine and trany temps.
On the CTS the tranny temp matches the DIC (both are digital - makes sense). The engine coolant on the CTS is about 20 to 25 degrees less than the gauge.
2017 Keystone Avalanche 320RS
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
nremtp143
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
Passin_Thru
I have an 06. Tow with the tow button in.
Shift it yourself and keep it out of overdrive (6th gear)
Shift down to the next lower gear at 2200 RPM.
Get an EDGE or a EFI tuner, Edge is the safest bet for towing.Run in TOW mode. Install it and a Pyrometer probe and you can then, more accurately, observe water, transmission and exhaust temp.
The fan should come on at 220 and run until temp is below 215.
They are big with a lot of blades so they are noisy.
Buy a set of Parker transmission cooler lines and replace you lines as they are the worst design in the world and you'll find puddles in your drive.
http://madjackdiesel.com/allison-1000-transmission/parts-pans-etc/diesel-race-parts-transmission-cooler-repair-lines-2004-5-lly-2010-gm-duramax-pick-up-trucks.html
A pump rub kit. http://www.merchant-automotive.com/transfer-case-pump-upgrade-kit.aspx Read up on it.
Then buy a pair of Timken fron hubs so when they go out you'll have the good ones as Chevy hubs last about 50K miles. Best economy is 65MPH towing.
ib516
If you're new to the LLY Duramax, you might want to See this.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
wcjeep
My Cummins engine fan start up sounds like we're preparing for flight.
time2roll
If the gauge does not move... it is not overheating.
Fan is normal.
Just because the diesel does not rev up like a gasser does not mean it is not working hard.
hmknightnc
Sounds total normal and expected depending on the load your carrying and ambient temperature. As long the temperature doesn't exceed around 220 for extended periods of time your fine.
I don't have a duramax currently but my cummins can easily climb to 220 when the fan kicks in and then stays there when pulling heavy up hills (horse trailer wieghing 18k#)
If your worried take into a dealer and have it checked but I wouldn't worry about it unless temperature starts to rise out of the normal range,
killerbee
The fan comes on to add cooling capacity. It does not indicate overheat. Because it is overdriven, it is quite loud. That is normal for LLY.
Michael, Systems Engineer and Professional DURAMAX Diesel Tuner
Killerbee Performance
sch911
Yes, normal... The fan needs to engage to keep it from overheating!
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
