New Truck 2016 RAM 3500 CCLB
2012Oudoorsman
Picked up my new truck on March 1st. It's a 2016 RAM 3500 CCLB Bighorn Cummins/Aisin. Ordered it Dec 26 and came in on Feb. 29. Worked perfect for me as we were mostly through the winter and no real salt was put down due to the mild winter.
Truck has a payload of 4039lbs and a gvwr of 12300. Pretty heavey at 8251lbs but im getting about 2mpg or so better than my 2012 RAM 1500 Outdoorsman with the 5.7l and 3.92 gears.
Haven't really used it yet but I can tell that it will be a huge improvement over the 1500. The 7500lb TT isn't really going to work it but I ordered the truck to be ready for when we upgrade to a fifth wheel.
A couple things I've noticed.
Ride is noticeable stiffer than my FIL 2012 F350 Scab LB and my friends 2013 F350 Screw LB. I aired down tires but still stiffer.
Everything I disliked with my 2012 changed. Location of trailer brake controller and gear selection now also tells you what gear you're in.
The Exhaust brake is awesome but I don't think this will be necessary for me. We do have decent hills but I haven't been on when on the interstate that I accelerates down. This may change when my gvwr FL goes from 13,500 lbs to over 20,000 with a new fifth wheel.
I think it really needs an upper overload like the F350s. With a tounge weight of 750-800lbs it dropped an inch and only had an inch left in the rake before being level. With a payload of 4000lbs I can't imagine it won't sag a good amount. The true test will be when I start loading some green oak firewood on it and we'll see.
15 REPLIES 15
2012Oudoorsman
So a couple people commented on my comment about the 1" drop with the tounge weight of my TT. So another reason I bought the 3500 with the 8' bed is so I can get as much firewood at our camp that I want. Cut down an Ash tree. Doesnt compare in weight to green oak but got two big loads anyway.
I never measured the first load but on the second load the rear was about .5" lower than the front. Yes it was loaded heavy in the rear because I dont have a hedache rack. Ill probably look into one but not sure if they work with tonneau covers.
Was about 3" from the bump stop hitting the axle and the lowest overload was not making contact with the leaf above it. My FIL 2013 F350 with upper and lower overloads would look very similar, his last 07 F350 would still be rear high without a doubt.
it could be one of the ways these trucks are designed and when they are at full capacity the rear is lower than the front. Its not going to bother me for now but if/when I upgrade to a fifth wheel I would probably consider airbags to eliminate this.
Also have seen a lot of these trucks lately, my reason for choosing white is that it hides any light scratches. I really contimplated ordering with the blackout package but I knew id go crazy over the scratches.
2012Oudoorsman
ACZL wrote:
Congrats fellow CNYer!White is a great color and aids in heat reflection as well.. Good to see others from CNY on here. OP, is that Romano's building behind your truck?
Nope its where I work, I dont take pictures that often so its all I had. The guys at work wanted to see it so I brought it in, I normally drive a company vehicle.
45Ricochet
Congrats
I can't believe how many new Rams the past few months.
They are like rabbits :W
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
bbaker2001
yes we are, first time, we are looking forward to it.
wont have kayaks on top, but look us up
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
Me_Again
bbaker2001 wrote:
beautiful truck, great color
enjoy the ride
we have the short bed. when I load up I drop 2". I did notice, we have 4 springs, the GMC has 4.
I do like the exhaust brae, what a difference from my 1500.
1st Ram for me and diesel, love it also
You going to be at the Cardinal rally in Jackson, Ca in May? Chris
ACZL
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
bbaker2001
enjoy the ride
BB from California
2015 Ram 3500
2001 Cardinal
IDoMyOwnStunts
Congrats! Nice looking truck! I'll bet the only problem you're going to have towing is wiping the huge grin off your face.
I'm done. This isn't a place to be helpful. It's a place where curmudgeons with a superiority complex will nit pick everything. If you want help, go elsewhere. Admin, delete my account please.
Hiking_Hunter
It's a stiffer ride now but you'll love the way a load smooths that out. MUCH nicer loaded. Same with mine.
Nice truck
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
racer4
Look great. Enjoy your new ride. I like the long bed.
I ordered a Ram 3500 in early January and picked it up 2 weeks ago. The new FW should be here in early May. I can't wait to hook up.
Chris and Pat
2023 Ram 3500 Limited, Cummins, Aisin, dually, Auto Flex Rear Air Ride Suspension
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB
nohurry
Congrats! That's a nice payload for a SRW diesel. Good travels with it.
Carl
2007 National RV, Sea Breeze
transferred
Congrats, helluva capable rig.
My experience with my MY16 SRW 3500 (there's three of us with that truck on this thread) is that the first thousand pounds sees the most squat relative to capacity. I think that's to provide an acceptable ride empty. So you noticed c.1" with 800 lbs weight but that won't change to near the same degree until you start getting closer to the 4,100 lb max capacity.
Basically what I'm saying is don't worry about your headlights touching the sky on a stock SRW 3500 unlike people with leveled trucks who hookup a trailer.
05 Ram 3500 SRW QCSB Laramie 4x4 Cummins, 610lbs, 23k GC, 9.9k GV
(totaled) 16 Ram 3500 SRW RCLB SLT 4X4 Cummins Aisin, 900lbs, 25.3k GC, 11.5k GV
06 F550 4x4 PSD, 570lbs, 33k GC, 19.5k GV
Nicholsfamily05
Great looking truck! We just up graded from our 2012 2500 Mega Cab Hemi to the 2016 3500 CCSB Big Horn Cummins.
We can't wait to see how it does with our fifth wheel. 12,000lbs. We are to curious to see how much our trailer makes the truck squat.
I was thinking the same thing they finally put the trailer brake in the right spot.
We actually thought it rose a bit nicer than our previous truck.
But we don't drive it very much unless moving our 5er or our ATV trailer. Had it just about a month only has 450 miles on it.
Pull your trailer like it's not even there.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
minnow
Nice looking truck there. I myself have a 3500 LB on order myself. As this will be my first Ram and diesel too boot, I've been reading the many Ram truck forums to learn as much as I can about the running and maintainence of this truck. One thing that keeps coming up is that we should run these trucks with the EB on all the time. Others say that it warms the engine up much faster and it keeps the engine running cleaner over the long run. Others here will have more knowledge on that I'm sure.
