Old Old Old Dodge truck Mechanical question
Pineapple_Kid
Didn't know where to post this Question but have lots of Bright
people here ( and some others who ? )
I have a 1964 Dodge D 100 It was my parents camper truck.
Just recently the steering has gone a wandering on it. Nothing
is loose underneath I can see. Of course no local shop will touch it or even look at it " Cant Get The Parts "
Some where in the back of my mind I remember the old steering gear boxes had an adjustment on them ??
Anyone have any suggestions ??
It is a bit of a classic and purrs like a kitten, coming up on 80,000
miles.
Aloha Leon
Pineapple Kid Kauai, Hawaii
2013 Ram 2500 crew cab diesel (In California)
2003 Jayco 243RKS fifth wheel (In California)
Right Hand drive Sprinter Motorhome ( in Netherlands )
17 REPLIES 17
zogg
raygreg wrote:
look here , lots of parts for old dodge
http://www.rockauto.com/
I was able to buy a lot of parts from Rock auto for my 1969 Ford Galaxie last year....they have lots of stuff for older cars
2016 Ram 2500 Crew Cab
6.4 Hemi, 4x4, 3.73, 6 Speed Auto
2016 Keystone Hideout 7500# Dry :B
dpatt67
Check out sweptline.org for most any knowledge you might need to know. Great trucks!
2015 Ram 3500 Laramie 4x4
2014 Cross Roads Zinger 31sb
Sport45
Has the alignment been checked?
โ€™19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
whsk
check LMC truck.com for dodge parts-they have a lot for the old style dodge trucks-whsk
Pineapple_Kid
What a great bunch of advise !!
Thanks a million I will get back when I do the research and find the problem.
It sure is nice to have a post with solid comments and not all the BS that most posts have.
Thanks again and Aloha
Leon
bguy
Is this truck power steering?
The first thing to check if you have no worn out BJs or TR ends or pitman/idler arms, is see if you have any looseness in the pot coupling. If all that is tight you can perform a sector shaft adjustment. One of the above posts is close but not quite on the procedure.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Sundance07
ScottG wrote:
Mikepy wrote:
On my old dodge, follow the steering column as it exits the firewall, there is a knuckle, this was stripped out and the parts store had one in stock. Had to anticipate a turn and start cranking the wheel before I got to it. Drove slow until I got home.
This is my best bet. This knuckle was used throughout the Dodge truck and car lineup into the nineties and is readily available. It's a terrible part that wears out quickly but at least it's easy to repair. Some times its housing is worn as well as the inside parts - the housing is the most expensive part and I think I paid $50 for it last time.
I agree.
More often than not it is the steering shaft. Borgeson makes the replacements.
2012 Ram 3500 4x4 CCLB/DRW Laramie, Cummins 6.7 HO, 68RFE, 4.10 Max Tow, Firestone Ride-Rite, 50 Gal Transfer Flow
2008 Citation Supreme Platinum XL 34.5 CKTS, GVW 15500, MorRyde, 4 wh disc brakes, -30C Polar Pkg
mowermech
Factory service manuals are often available for those old Dodge/Fargo trucks on eBay.
Chiltons also has manuals available for them.
I have both for my 1977 Dodge.
Look here:
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR10.TRC1.A0.X1964+Dodge+truck+service+manual&_nkw=1964+Dodge+truck+service+manual&_sacat=0&_from=R40
CM1, USN (RET)
2017 Jayco TT
ScottG
raygreg
PUCampin
If you find your steering gear box is worn out, there is a company that specializes in quality steering gear boxes called Redhead steering gears (redheadsteeringgears.com). In the unlikely event they don't have one for your vehicle, they can rebuild yours for you. When I was part of a dodge community, the steering box was a common item to wear out, and this company was the go-to company for the replacement.
I had a 72 W200 power wagon. 318, NP445 4spd, NP205 gear drive transfer case, 4.10 axle gears, 35s. Was planning on building it up as a toy. Should never have sold it.
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp = PUCampin! (Sold)
2006 Pioneer 180CK = (No more PUcampin!):B
Me:B DW:) and the 3 in 3 :E
DD:B 2006, DS ๐Ÿ˜› 2007, DD :C 2008
Vulcaneer
byronlj wrote:
There is a stud with a slot for a screwdriver locked in place by a jam nut on top of the steering box. Loosen the jam nut and then tighten the stud gently. If you tighten too much you can lock the steering or lose steering to one side. Check this before driving! I had a '62 dodge in high school and it did this. It always was loose though. I replaced lots of steering components which didn't help much.
Dave
This would be my guess too. I believe it's an old recirculating ball screw system. This screw takes up the slack.
But as another poster advises. These systems tend to wear in the area where they are used the most. Makes sense. More wear in the center of the shaft and less at the extreme ends. So I would adjust this way.
Before you adjust, make sure you have the steering box full of lubricant. These old steering boxes had a reputation for leaking the grease out over time. If the grease is gone, the ball screw wears prematurely. And even if it does not, the lack of grease can make the box seem loose.
Also make sure all the components are well greased, before you start adjusting the steering box.
Adjustment steps:
1) Raise the front end off the ground. With enough wheel clearance so you can turn the wheels lock to lock. 2)Crank the wheels all the way to the left and to the right. Does the steering wheel pressure seem consistent? 3)Then take up the screw a little. Lock the nut on the screw. Repeat step 2. Consistent? Free play feel any better? Repeat step 3 until you feel an acceptable amount of free play. And the steering wheel pressure is consistent from lock to lock. Tighten the lock nut and try again.
If you feel the steering wheel feel tighter at one end of the stroke, that is the area with the least amount of wear. And that area is where your best compromise (free play and backlash) adjustment can be made.
If a little adjustment and no real improvement in steering, you have looseness in other steering components.
I agree you can find parts for these. And these are great old trucks. Glad you want to save this one.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
dodge_guy
Check for loose parts first. If everything checks out ok go for an adjustment on the gear box. Parts are still available, you just have to find a place willing to work with you!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
azrving
You have to look at the whole system with a helper. Someone needs to sit in the truck and gently work the steering wheel back and forth while you look at everything. I dont remember what system that old of a truck uses but it could well be a solid beam axle. Look at each tie rod end for any movement. Look at any rubber bushings and spring mounts. Lift the front end off the ground and check for play. be careful when adjusting the gearbox as it can be worn and tightening the screw in the worn area results in to tight of a feel as the wheel is turned. There may be a combination of several loose areas. Rubber parts also deteriorate with time.
