Sep-17-2014 09:43 AM
Sep-21-2014 08:31 AM
Sep-19-2014 06:41 AM
Sep-19-2014 06:13 AM
Sep-18-2014 01:32 PM
Sep-18-2014 12:49 PM
APT wrote:I see on the kit you linked to it show a standard 110 plug, did it also come with 12v hookups? Also whitch setup did you get from that seller, I see 4 waterproof ones. Thanks.
I used lights that hung from awning for a year before getting something like this LED kit. Way way way way way better. Roll up with the awning. whatever color to match our mood.
Sep-18-2014 10:24 AM
JesLookin wrote:
We mounted our LED strip on the camper just below the awning. Mounting this way the lights can be used any time, independent of the awning. I routed the wires up over the top & down the ladder.
Sep-18-2014 07:50 AM
Sep-18-2014 07:26 AM
Sep-18-2014 07:05 AM
Sep-17-2014 04:17 PM
Sep-17-2014 01:09 PM
Sep-17-2014 12:41 PM
Sep-17-2014 12:26 PM
Sep-17-2014 11:37 AM
hawkhill wrote:
We had the same challenge that you have. We actually went to putting our rope lights on the ground around the patio area for two reasons. One - you are not suppose to tie down a power awning, so to save it in bad weather, we found it is easy to put it in if you don't have to worry about taking off the lights and two, we could not find a secure way to secure the rope lights to the awning. We have talked about having led rope lights permanently installed right under the awning.
