Dec-30-2014 10:10 AM
Dec-31-2014 06:46 AM
otrfun wrote:
My next truck (4x4, CC) has to have a minimum 3000 lbs. of payload. That leaves me with either a 1 ton diesel (3500-4000 lbs.) or a 3/4 - 1 ton gasser (3200-4000 lbs.).
I've run my gasser vs. diesel numbers as far as purchase price, MPG (towing & empty) and resale.
I'm familiar with what's needed to maintain a gasser; however, never owned a diesel. Here's what I know, don't know, about diesel maintenance:
1. Oil costs are approx. double vs. a gasser due to twice the oil capacity.
2. Oil filter. I assume these cost a bit more than a gas oil filter?
3. Fuel Filters. Assuming DIY replacement, what can I expect to pay for filters? How often?
4. DEF. 2-4 cents of DEF used per a gallon of diesel??
5. Valves. Under normal operating conditions is adjustment ever necessary? If necessary, cost?
6. Injectors. Under normal operating conditions is maintenance/replacement necessary? If necessary, cost?
Other diesel specific maintenance items I may have overlooked?
Thanks!
Dec-31-2014 02:51 AM
jerem0621 wrote:
I wouldn't let maintence fees stop me from owning a diesel. If a few hundred bucks a year mean the difference between affordable or not then you are in no position to buy a truck.
Dec-30-2014 08:15 PM
Dec-30-2014 06:59 PM
This depends. If you can use conventional (rarely/never below 0 degrees F), you can use dino 15W-40. You can get 12 quarts (3 gallons) for roughly $40. Only $10 more than what I spent on average for my F-150 running semi-synthetic 5W-20(minimum oil requirement per Ford back then). Or if you go full-synthetic, you're looking at roughly $63 in oil (I buy T-6 Rotella 5W-40 for about $21 per gallon).
For my truck, oil filters are roughly $11 to $13 for an oil filter. I like the LF16035 since it is a synthetic filter, so I've been spending roughly $13 per oil filter.
For my truck, it's roughly $110 for both filters. It's a yearly change-out for my truck (annual or 15,000 miles. Whichever comes first)
Just to make life easier, I figure a nickel per gallon of diesel. This is assuming you're paying around $2.80 a gallon for DEF
Every 150k miles. For the Cummins, you can DIY, just need a feeler gauge and a breaker bar to rotate the engine. Ford and Duramax don't require this service as I believe they both utilize hydraulic lifters.
These should last a minimum of around 300,000 miles in the worst of conditions. Longer in better conditions such as higher speed towing
Specific to the Cummins motor, you do have to occasionally change the Crank Case filter which costs about $77 when I last looked. This is done every 67,500 miles. However, this filter does an excellent job of keeping most of the oil mist out of your intake tract. I know Ford utilizes a service-free cyclone crank case filter unit, and I'm unsure what Duramax uses. That's the only thing I can think of adding to your list
Thanks!
Dec-30-2014 05:46 PM
Dec-30-2014 03:39 PM
Dec-30-2014 01:41 PM
Dec-30-2014 01:28 PM
Thanks!
Dec-30-2014 12:54 PM
Dec-30-2014 12:47 PM
Dec-30-2014 12:17 PM
Dec-30-2014 12:08 PM
Dec-30-2014 11:49 AM
Dec-30-2014 11:43 AM
Dec-30-2014 11:04 AM
ib516 wrote:
Depends on the diesel.
I would argue that a Cummins diesel 2006 or older isn't any more expensive to maintain than a gas powered truck of the same era. Oil cost is double, but it goes 2x as far between changes. Oil filters are $20 and fuel filters are about the same ($15 - $20). They both need brakes and tires, belts etc, and the gasser need spark plugs and PCV valve that the diesel (2006 or older Cummins) doesn't.
I will agree that if a diesel breaks down (engine related), it can be very much more to repair than a comparable gas engine truck, and that the newest crop of diesels might be more expensive to maintain than the older ones, so they might be more than a new gasser -- but I'm not as familiar with them as I've never owned one.
I wouldn't let maintenance costs influence your buying as I think they are pretty close. Resale, initial cost, what you plan to use the truck for, and in what conditions would be better metrics to decide which one to buy IMO.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
