Dec-30-2014 10:10 AM
Jan-01-2015 06:31 PM
gtsum wrote:
I went from gas to diesel and would never go back. I think you can make the argument either way about which cost more to own and operate (fuel vs gas price, maintenance costs, repair bills, upfront cost vs resale cost, etc, etc), but bottom line is they tow better. I like how they drive better as well (ie not revving to 4000 rpms to make any power). I ordered my diesel new and have 100k bumper to bumper warranty..got it for less than 1k...if something happens after 100k miles, so be it...
Honestly, if someone is basing a decision on a few hundred bucks either way on maintenance or buying 2 batts vs 1 batt, I doubt they should be buying a new truck in the first place
Jan-01-2015 05:59 PM
Jan-01-2015 09:19 AM
Jan-01-2015 09:16 AM
1Longbow wrote:
When I bought my 2008 cummins ,the dealers had the oil change for life deal,and while it saved some money ,it always seemed they found something else to charge me for every time I brought it in. I don't think I've ever changed the differential lube more in any truck I've ever owned. But to continue with the "free" oil changes you had to do what they said needed doing. The final straw for me was when a service light came on ,at 65000 miles and they told me it was an $800 charge to change a filter and clean some emission screen. They truck run perfect,and Cummins list no such thing. Come to find out its a Dodge thing. I decided to go else where.
Jan-01-2015 08:25 AM
Dec-31-2014 03:21 PM
Dec-31-2014 11:38 AM
phillyg wrote:
I did a lot of research before committing to a diesel truck. I concluded maintenance would be roughly three times the cost of gasser maintenance, paying someone else to do the work.
I just paid the Ford dealership $458 to do oil and filter change, 2 fuel filters, air filter and coolant flush, so I think my research pans out.
I think I could have saved a few bucks elsewhere but didn't have time to shop around before heading out.
Dec-31-2014 10:37 AM
Dec-31-2014 09:56 AM
Dec-31-2014 09:46 AM
majorgator wrote:jerem0621 wrote:
I wouldn't let maintence fees stop me from owning a diesel. If a few hundred bucks a year mean the difference between affordable or not then you are in no position to buy a truck.
^^^THIS^^^
Simple answer: yes, a diesel costs more for routine maintenance. Whether you're buying new or nearly new/barely used, you're going to drop $30K to $50K on your TV. Maintenance fees are so inconsequential to the full cost of ownership.
Dec-31-2014 09:25 AM
Dec-31-2014 09:00 AM
If you need a diesel for your trailer then there is no substitute. If you want a diesel then there is no substitute. ..I don't care if your pulling s pup....if you want a diesel then that's all that will scratch that itch.
If you want a tool that will do the job economically (lower price of entry) and fit the ratings you need for the trailer then a gasser makes great sense.
Not to start a gas vs diesel war... At all... But many people choose diesel when a gasser would be fine for a few simple reasons
1) MPG while towing can be significantly better with a diesel
2) Some people are RPM adverse and try to make a gasser perform while keeping the RPM under 3000...this makes the gasser unable to performe.
3) the option to use the big truck lanes while pulling the trailer while fueling up
4) The personal desire to have the biggest and most power available
I am sure there are others...
In the end... Get what you want!
Thanks!
Jeremiah
Dec-31-2014 08:30 AM
Dec-31-2014 07:58 AM
