May-11-2015 07:16 PM
May-14-2015 06:41 PM
chuckm99 wrote:
TakingThe5th,
What do you use to monitor the temps of the tires?
Thanks.
Chuck
May-14-2015 04:07 PM
larry_kruzan wrote:Cummins12V98 wrote:
I ran 80 front all the time 45 rear solo and 60 loaded with 5K pin on my 11 RAM LongHorn Dually. At 40K the tires looked great. Only rotated fronts side to side. My 15 I am running 80 front all the time 40 unloaded and 60 loaded rears.
Pic of MS2's at 40K.
I'm tire shopping for my dually right now. Due to your obliviously great life I think I'll give Michelin MS2's a try this time. I ran them on my vans a few years ago and had great service, but I've but the dually IS a lot different.
May-14-2015 03:45 PM
May-14-2015 01:59 PM
chuckm99 wrote:
TakingThe5th,
Thanks.
Chuck
May-14-2015 07:53 AM
May-14-2015 06:09 AM
May-13-2015 07:14 PM
May-13-2015 01:51 PM
May-13-2015 09:50 AM
Bedlam wrote:
Some of the split feeds I found have a check valve at each tire to prevent one bad tire from taking out both, but leakage at multiple fittings is my concern.
May-13-2015 09:00 AM
May-13-2015 08:45 AM
Troy35 wrote:
First, what method are you all using to fill them up? I plan on just getting a long rigid inflator to push into the inside valve stem.
Troy35 wrote:
I've seen other options that extend the valve stem or even tied the two tires together with a metal air hose.
May-13-2015 08:13 AM
May-13-2015 07:46 AM
May-13-2015 05:05 AM
