โJun-09-2023 07:44 AM
โJun-13-2023 04:48 PM
MFL wrote:
^ Yep I agree! The OP had a QUICK QUESTION to ask, and hasn't returned since.
I haven't read all the pages, but I don't believe the civil suit guy has shown up YET??
โJun-13-2023 01:29 PM
โJun-13-2023 12:43 PM
โJun-13-2023 09:53 AM
mkirsch wrote:Cummins12V98 wrote:
BUT, BUT, BUT I can't load to that RATED number.
Acceleration and braking. When you accelerate the weight shifts to the rear axle. When you brake the weight shifts to the front axle. Loaded to GVWR, every time you stomp a pedal, you are overloading an axle.
Why not on larger commercial trucks? Because those trucks are not capable of the levels of acceleration and braking a pickup truck is.
โJun-13-2023 08:16 AM
Cummins12V98 wrote:
Here is the actual OFFICIAL SAE ratings. My truck is an AISIN 3500 DRW Crew Cab 4x4, all the numbers are there for MY specific truck. Read the last line that is specific to MY truck.
Any more thoughts gang???
โJun-13-2023 07:33 AM
โJun-13-2023 06:39 AM
valhalla360 wrote:Cummins12V98 wrote:valhalla360 wrote:Cummins12V98 wrote:
PLEASE tell my WHY they have a 9,750# SAE rating on my rear axle and I can't load to that??? I don't care if I am hauling WIDGETS, same thing.
Simple...that rating is for the rear axle. GVWR is a different rating.
It's like the newbie who says their unibody station wagon has a 6000lb tow rating but the hitch is limited to 300lb dead weight. Realistically they will never be able to pull 6000lb without exceeding the hitch limit.
Yes.
Maybe if you had a gas regular cab, you might be able to do it. They only carry so many axles.
โJun-12-2023 08:26 PM
โJun-12-2023 07:10 PM
โJun-12-2023 06:06 PM
โJun-12-2023 06:05 PM
WHY are you YELLING?
Lol
โJun-12-2023 12:07 PM
โJun-12-2023 08:51 AM
Lantley wrote:Cummins12V98 wrote:Cummins12V98 wrote:Lantley wrote:
Taking the idea that GVW is a performance and manufacturer's rating only.
Does that mean GVWR doesn't matter and can be ignored?
I don't think so. All the ratings have some significance and should be factored into your decisions.
I never get a good answer on this one.
How can I load my rear axle to it's RAWR of 9,750# and not add a single pound to it's front axle weight of 5,250# and be within the 14k GVWR???
I got booted off IRV.NET over disagreeing with SmokyWren a monitor on this subject.
No one wants to tackle this one??????
If I understand correctly you can't load to the full rear axle rating without exceeding your GVWR.
Much in the same way you can't tow a 15k bumper pull RV without exceeding the hitch rating.
Sure you may be within one rating but exceed others. I'm not sure what's so complicated about that!
โJun-12-2023 06:50 AM
