Ram 2500 CTD tires (issues, and suggestions)
Bheffington
I just bought a 2012 Ram 2500 CTD and pulled my new Springdale 293rkssr 400 miles. The trailer actually pulled very good. My wife drove behind me and said the trailer did not sway. My issue is the truck came with Nitto trail grappler mud tire. The thread is way too flexible and the truck wanders all over the road, almost scary to a point. I need to swap out tires and though I would pick the minds of those here. Stock tires are an option but I would like an all terrain tread if there is one that suits pulling.
14 REPLIES 14
transamz9
Bheffington wrote:
They are E rated. I honestly don't know if any other mods have been performed to the truck. Driving without the trailer, everything seems fine. I may just go ahead and get a new set of wheels and tires and switch them when I tow, which isn't often. Ill take it to a shop later this week to have the front end checked out.
If it has a leveling kit on it then your front fenderwell will be about the same distance off of the ground as your rear. Stock, the rear is 2-2 1/2" higher than the front.;)
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
rickgu
I have Nitto Terra Grapplers on my Chevy. I know it's a different truck and tire tread but when they're new they are squirmy and seem to wander for like the 1st 500 miles. Then after that they're just fine, it's done that on every set I've owned. It's bad enough that my wife notices it, and she can tell when it went away.
2003 1500HD 6.0 L 3.73
2007 Jayco Jayflight 27.5 BHS
pronstar
I would figure out what was on your truck, before I threw money at wheels and tires...because it may not be a tire issue at all.
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
Bheffington
transamz9
ecoast wrote:
if those tires are not 'E' rated, you will have issues.
My tires are not "E" rated and I don't have any problems.;)
ecoast
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
4x4ord
My BIL is running Nitro Trail Grapplers on his F350 with no concerns. Like has been suggested, maybe your suspension has been altered. Does it only handle poorly while towing?
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
mudfuel07
What size Trail Grapplers? I had 295/70R18's and loved them for towing. Something may be wrong with the front end. I kept mine aired up to 80 psi no matter what.
2020 Ram 2500 6.7 CTD 4x4 Tradesman(with a few toys)
2020 Puma by Palomino 32RBFQ for the kids!
transamz9
You bought the truck with MT tires on it, check to see if it has a leveling kit on it also. If it has a leveling kit installed and has not been realigned then it will drive funny because of the caster change.
ScottG
I have Toyo AT's and they're great for everything. Except towing is ripping the hide off them. ๐Ÿ˜ž
45Ricochet
Bheffington wrote:
I will mostly be on highways but the winters can get slick here. Maybe two sets of tires are called for, one for towing and one for daily driving. I had all four tires at 70 psi. The sidewalls call for 80 psi max.
I run two sets of wheels and tires also to avoid chaining up. Steering drift is a known issue on some of the solid front axle trucks though.
I'd take it to a well known front end shop 1st to check the camber etc.
Nitto's are nice for winter but they will burn out pretty fast in summer heat while towing.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Bheffington
Rich1961
What air pressure are you running in the tires?
Rich
2016 Chevrolet/Duramax 3500HD Dually Crew Cab B&W RVK 3700 5th Wheel Hitch
2014 Arctic Fox 29-5T
coolbreeze01
All terrain tires usually squirm when new and the only real advantage is on snow. If you don't intend to tow/drive on fresh snow, most any highway tire will work just fine.
2014 Sandsport 26FBSL
