Dec-12-2017 03:11 AM
Dec-12-2017 04:47 PM
FishOnOne wrote:
I believe it's fair to say that they didn't have either truck setup in the optimum setting. Which says a lot about the engineers of these trucks. The optimum setting should be clear and concise for anyone who drives these trucks.
Dec-12-2017 02:09 PM
ktmrfs wrote:
why didn't they set cruise control going downhill on the duramax? If you do with the exhaust brake on in tow/haul it will just hold the speed you set. works fantastic for me.
And yes, the GM reciever is a tough one for safety chains. I had to get different hooks for mine to fit easily. they could have done a better job.
Dec-12-2017 02:08 PM
Dec-12-2017 02:04 PM
Turtle n Peeps wrote:
^^^^^ this. I agree with everything that was posted above. That's why the Dmax burned less fuel. But it could have went the other way depending on load.
Dec-12-2017 02:01 PM
Dec-12-2017 12:35 PM
Dec-12-2017 11:22 AM
Dec-12-2017 10:42 AM
Dec-12-2017 10:03 AM
Trackrig wrote:
I agree, towing 12,500# isn't much of a chalange.
The Ford F450 towing 30,000# up the Ike.
Bill
Dec-12-2017 09:12 AM
ShinerBock wrote:
I agree. Towing a 12.5k lb bumper up the Ike may be challenging for a gasser 3/4 ton, but not for any of the diesel mills. They just make it a "non event" which is what you want out of a tow vehicle. Maybe bumping it up to around 16.5k lbs or better yet a 13-14k 5th wheel might make the test a little more interesting.
However, I understand that they can only work with what they got. The trailer they have may not be able to carry 16.5k and the 3/4 ton trucks that the manufacturers provide them may not have the hookup for a goosekneck or 5th wheel.
Dec-12-2017 08:24 AM
Dec-12-2017 07:45 AM
Dec-12-2017 07:19 AM
N-Trouble wrote:4x4ord wrote:
I suppose if they conducted an acurate towing fuel economy test where they started with a clean dpf and ended with a clean dpf it might be interesting.
Winner winner chicken dinner... Yet every diesel fuel economy comparison fails to even touch on regen frequency and duration which have a bigger impact on economy than anything else.
Dec-12-2017 06:48 AM
Dec-12-2017 06:39 AM
