Dec-07-2016 11:15 AM
Dec-11-2016 08:49 AM
Dec-11-2016 07:36 AM
Dec-11-2016 06:50 AM
ShinerBock wrote:
Due to gear multiplication, the 650 lb-ft Cummins with the G56 is actually putting down considerably more torque than a SRW 900 lb-ft Cummins with the Aisin in first and second gear. In third, the G56 is still putting down more torque, but not much more. The Aisin is only putting down slightly more torque in fourth through sixth.
G56
1st: 13204.62
2nd: 7291.44
3rd: 4401.54
4th: 2912.13
5th: 2223.00
6th: 1645.02
68RFE
1st: 8837.28
2nd: 5034.24
3rd: 3857.76
4th: 2736
5th: 2243.52
6th: 1723.68
AS69RC
1st: 11542.5
2nd: 6156
3rd: 4124.52
4th: 3078
5th: 2370.06
6th: 1939.14
Dec-11-2016 04:32 AM
Dec-11-2016 04:03 AM
blofgren wrote:KBOnTheRoad wrote:
I have a 2016 Dodge Ram Cummins with the 6 speed auto and I can say without reservation that it's the best transmission I have ever driven. No tonly that but it works in tandem with the tow haul mode and the engine brake to make descending long steep grades a breeze.
The 6 speed will downshift automatically when needed and work with the engine brake. You can set the engine brake on FULL or Auto. Auto will let you set the speed you want to descend a hill at and it will keep you there.
And the fuel milage will be much better with the auto trans than the manual.
By all means get the auto.
By the way I have tested mine from the Baja to Alaska and back this year so it's seen a bit of everything.
Glad to hear you're happy with the automatic. How do you figure the auto is much better on fuel than the manual? Manuals are typically MUCH better at getting power to the road which makes them better on fuel.
Dec-10-2016 03:51 PM
G56 has a .74 overdrive in sixth, and 1.0 in 5th. The Aisin has .63 overdrive in 6th a .77 in 5th. 68RFE is .63 in 6th and .82 in 5th. With the advent of locking TC the advantage of manual trannies was negated. When not locked a TC has a torque multiplying capability.
Love my Aisin with low 1st and 2nd gear and 3.42 tall rear gears.
Chris
Dec-10-2016 03:18 PM
Dec-10-2016 02:46 PM
Dec-10-2016 02:13 PM
transamz9 wrote:
I had a SB DD in my 2010 that was in it when I bought it. IDK what the material was that it was made of but I hated it. I think it was designed to pull a sled. Spool it up and let out. There wasn't any easing out and it squalled every time you took off. Sound like I was barking tires every time I took off. It also sounded like someone had thrown a hand full off gravel in the transmission when it was sitting and idling with the clutch out. It sucked in a parking lot.
Dec-10-2016 10:59 AM
Dec-10-2016 08:14 AM
Dec-10-2016 07:40 AM
Flashman wrote:
Well with almost 200,000 miles on my 2006 2500. I started thinking about a new truck. My current Dodge has the 6 speed manual and I thought I was done with manuals but I noticed that Ram still offers the manual. Does anyone know the horsepower torque and towing of the 2017 Rams equipped with a manual.
Dec-10-2016 04:31 AM
Dec-09-2016 06:00 AM
Dec-09-2016 05:09 AM
Grit dog wrote:
To rfhago s point, a mild dual disk Southbend like a DD3250 is smoother engagement and less pedal pressure than a stout single disk like an OFE, in my experince.
Not necessary to go with a DD clutch for the application we are talking about, but now that I'm on my second single disk SB clutch and having driven a few DD SB clutch trucks, I'd go DD from the get go.
Of course my single now rattles more than any DD clutch. Southbend did me a solid when I wore out the OFE and made me a one off full ceramic (buttons) single with a 3600lb pressure plate in an old school 3 finger design with roller tips.
Takes a lot of leg to disengage it, but it holds like no other single I've seen and rattles so loud with the rollers that my CR sounds like a 24V idling with the clutch engaged!
And the price was right. $500 + shipped to AK because the Rep at SB thought my clutch didn't last as long as it should have. Got 85kmi out of it only.
Lifetime SB customer here after service like that!
