Mar-08-2014 01:37 PM
Mar-12-2014 05:37 AM
Mar-12-2014 04:37 AM
Sheriffdoug wrote:Mello Mike wrote:jdcellarmod wrote:
Mike, which wind generator are you planning on using? I thought of doing the same.
Jeff
Probably through these folks. I met them at last year's Overland Expo.
Free Spirit Energy
Mike,
I have one, they work well but are quite noisy and vibrates through your roof if it is quite windy.
Do some more checking.
Checkout the sailing yacht type ones, they appear more aerodynamic, but they too make be noisy as well.
Good Luck,
Doug
Mar-12-2014 01:32 AM
Jeff
Free Spirit Energy
Mar-11-2014 10:30 PM
hedge wrote:
I'm surprised at the strength of the ladders from the pics above. I am now considering adding a bike rack like that.
My camper came with a 'phat' ladder, it has bigger tubes than the standard. Does anyone know if it's better/worse/same strength as the standard ladders?
Mar-11-2014 10:03 PM
Mar-11-2014 07:17 PM
Mar-11-2014 06:45 PM
Mar-11-2014 12:20 PM
Carb Cleaner wrote:
Fork mount bike rack. This is our last campsite after 19 days and 3,400 miles with two different pairs of bikes loaded. First, two 26" bikes. Then, in Austin, both 26" went to the roof rack and two new 29ers went on the ladder rack. That's a story for a different day. I'll do a write-up on the rack build, eventually. I gotta make it longer for the 29ers' wheel-base. You guys have seen this before, about a month ago.
The ladder is completely intact. The bikes are about 30 pounds, each, less the weight of the front wheel. I used a four foot step ladder during loading/unloading.
Mock-up, before I added PVC to hold the rear tires:
Mar-11-2014 12:00 PM
Mar-10-2014 08:39 AM
workhardplayharder wrote:
Mother-in-law
Mar-10-2014 07:43 AM
Mar-10-2014 07:40 AM
tdium wrote:
I bought a standard aluminum L shaped ladder bicycle rack and used it to carry my 2000 Honda generator. I made a plywood base with recesses to accomodate the generators feet, then bolted the base to the rack. I found a small generic outboard motor cover at Princess Auto ($19.95)that looks great and fits perfectly to cover the unit. The unit is locked down and has a simple double tie down system.
It has withstood the test of time...about 6 years and all types of weather. I have even run it for a while on the ladder rack for short periods to run the microwave.
I have occasionally used it for a bike too.
Cheers
Mar-09-2014 05:59 PM
Mar-09-2014 03:45 PM
Jeff
