โJun-20-2014 10:33 AM
โJun-28-2014 08:20 AM
โJun-27-2014 08:19 PM
โJun-27-2014 07:32 PM
Lantley wrote:
Seems like a lot to go through just to reduce TW.
I would either move other cargo not batteries to rear store and go . Or build a rear platform for back of trailer.
The batteries are kept outside of the living space for a reason. Why put them into a living /sleeping area. There is a risk associated with the batteries. I would seek a different solution.
โJun-27-2014 09:35 AM
โJun-27-2014 09:34 AM
โJun-27-2014 04:27 AM
โJun-27-2014 03:44 AM
โJun-27-2014 02:44 AM
โJun-26-2014 10:18 PM
โJun-21-2014 05:24 AM
โJun-20-2014 01:24 PM
โJun-20-2014 12:54 PM
โJun-20-2014 12:53 PM
RoyB wrote:
If you vent the batteries be sure it is a box that is vented not just a vent for the larger area where the batteries are sitting. All those fumes are very corrosive and will attack anything metal.
Also if you boil out the fluids you need to address where the run-off is collected or bypassed to.
The battery fumes are also very explosive and should not be around anything that can spark on you.
I personally would not like having wet cell batteries anywhere close to where I would be sleeping. To me batteries belong outside on the trailer tongue but you gotta do what you gotta do sometimes...
If money was no object here I might think about getting some sealed AGM type batteries if they were to be used inside the trailer.
Roy Ken
MM49 wrote:
I like your idea of moving batteries, but your plan will not work.You are loading a 150lbs on the heavy side of your trailer.
MM49
โJun-20-2014 11:03 AM
climb.on wrote:I like your idea of moving batteries, but your plan will not work.You are loading a 150lbs on the heavy side of your trailer.
I am moving my pair of Costco Golf Cart Batteries from the tongue, to the rear of the camper under the bunk area. Primary reason is to get my tongue weight down a little bit. I've done all the calculations and scales visits and this is a good solution to keep me in the 900-1100 or 12%-14% tongue weight range.
So I would obviously need to put the batteries in a sealed, secured and vented battery box top and bottom - no problem. The new battery location would be located right next to the charger/converter, so wiring would be very convenient. This pic shows the new location.
Question: Is rewiring the batteries in a new location, as simple as I think it is? Battery negative bonded to the frame and Battery Positive to the 2nd lug of on the charger/converter circuit board (see picture)? I would also add a battery disconnect near the new battery location, like we have up front.
Also, there are electrical component wiring (emergency brake, tongue jack,etc) at the old location on the tongue that I think will still operate as long as I leave the existing positive battery cable in tact. I will leave all the existing wiring to the front, in tact anyway, as to easily return to the original setup if desired and to keep power to the front junction box. Is there something I am forgetting to consider here?
โJun-20-2014 10:49 AM
