โMay-24-2016 03:15 PM
โAug-13-2024 05:50 PM
I have had this issues with a double brass trailer plug, it just would not plug in. I got a single brass pin out and fit perfectly
โAug-14-2024 03:39 AM
You are replying to a question from May 2016. They probably figured it out by now.
โMay-25-2016 05:06 PM
โMay-25-2016 04:27 PM
โMay-25-2016 10:08 AM
โMay-25-2016 08:26 AM
whosgreg wrote:
My 2007 Ford truck had the same connector you have. The 3 grooves in your connector are much wider and flat. Mine has 3 narrow grooves and both are raised with the middle row sunken. The Ford one is a twist type one. I might have to change the connector which I'm trying to avoid. It's much easier to change the plug. ๐
โMay-25-2016 05:53 AM
โMay-25-2016 03:11 AM
โMay-24-2016 10:31 PM
seaeagle2 wrote:
On my 2010 F150, I had to install the fuses and relays for the the plug to be powered. there may be a bag of fuses and relays in the glovebox.
โMay-24-2016 09:19 PM
โMay-24-2016 07:59 PM
โMay-24-2016 07:20 PM
โMay-24-2016 07:01 PM
โMay-24-2016 06:51 PM
