Jun-08-2013 07:38 AM
Jun-11-2013 08:56 AM
tcc11tcc wrote:
BDGT?
Jun-11-2013 08:54 AM
Wishbone51 wrote:
The BDGT is a must-have.
Jun-11-2013 08:53 AM
Jun-11-2013 08:49 AM
Jun-11-2013 08:25 AM
tcc11tcc wrote:
Don't let me make another mistake!!! I can trade my 2011 Yukon for a 2011 Nissan Armada Platinum 4x4 (which says 9000lbs for tow capacity) and come out even. Same year, same mileage, Nissan has more options by far. Would this be a better tow vehicle for me. As I said, I don't want a truck. I tow a 19' bass boat all over the south & the camper will be towed long distances at times too. I had an Armada before the Yukon but it wasn't fancy. Towed the boat like it wasn't there. Now I am kicking myself!!!!
Jun-10-2013 06:28 PM
APT wrote:lbrjet wrote:
3.08's are terrible towing gears.
While that is not the gear I like, it should be fine for towing that RV. It's very similar to the older 4-spd trans with 4.10 axle.
That bigger issue is that you do not have the HD towing package with additional transmission cooler that is only available with the 3.42 axle. Your tow rating is under 5500 pounds.
This is a good reference thread for you.
I recommend getting a trans cooler, using tow/haul like you have, and M4. You want to cruise in the 2200-2800rpm range on flat ground and let it downshift on hills to whatever you want to hear or pay the fuel for.
Jun-10-2013 04:39 PM
chracatoa wrote:
That's funny... I haven't thought about that! 🙂
Jun-10-2013 04:03 PM
Wishbone51 wrote:chracatoa wrote:
My wife bothers me when I get to 4000 RPM in our Sequoia. It's rare, but it does happen. She thinks it's bad for the engine. The dial goes up to 7000 RPM.
haha... I get the "You're going too fast!" because it sounds fast 🙂
Jun-10-2013 02:29 PM
Jun-10-2013 08:54 AM
GMT830 wrote:That's only the Ecoboost ads your thinking of .... :B
Because the ads on TV say I can
Jun-10-2013 07:50 AM
Jun-10-2013 06:27 AM
Jun-09-2013 07:47 PM
Jun-09-2013 06:48 PM
tcc11tcc wrote:lbrjet wrote:
From the description of your situation I was thinking you probably had the 3.08 gears. Now you confirmed it. I made the same mistake in 1987 and the good thing is you only make it once.
Same mistake?
Jun-09-2013 06:44 PM
